Originally Posted by Trick440
I have a Revo 2.5 chassis, stock tranny locked into second.
I want to use the Traxxas center diff., I would need the diff., the shorter output shaft.... and do I still need a forward only conversion kit?
thanks
I would do it....
did you lock the tranny in 1st gear yourself? if so I would have installed the FOC at the same time the reverse gears are weak and if you are using the RCM mount you will have motor breaking and reverse since you will have the tranny locked
