Quick Hyperion question
Jbreddawg
Jbreddawg's Avatar
Quick Hyperion question - 04.25.2008, 08:01 PM
Hopefully , since I already ordered the 0610i !! to charge my trakpowers, I just use the trackpower balancer ? I would not use the built in balancer correct ? I think I will have to use the trakpower balancer just to hook the batts up to the hyperion charger without making a custom harness. Am I correct on this ? Thanks
The wheel may be turning, but the hamster's dead .
04.28.2008, 09:44 AM
Yes you can either balance using the trakpower balancer and then charge the battery with the hyperion or make a set of custom charger / balancer leads which shouldn't be that hard.
azjc
05.03.2008, 02:30 AM
I have the Flightpower balancer and with it you connect the input leads to the charger and it has 2 output and the balancer leads coming out the other side of the balancer, so I am assumming the the Trackpower is similar
Jbreddawg
Jbreddawg's Avatar
05.03.2008, 08:28 AM
Thanks ! Still waiting on my charger to arrive , hopefully soon !
