Hyper St conversion
Hyper St conversion - 04.27.2008, 08:36 PM
Have not seen too many of these truggies on the forum, and now the the MMM is out, I figured it was time to start my conversion!
I picked this rtr model up used, $150 for the truck with everything and spares, so a decent deal. Still need to sell the nitro engine, and a few other nitro related parts. It also needs a good cleaning, as you will see in the pics!
Planned setup is a MMM running a 10xl, on 6s lipo. Picked up a neuenergy 3900 6s pack cheap from amain ($125), and the 10xl was from another member here. I will see how it does with the 10xl, but I would really like a 1515 2.5d. I am waiting to buy one, as CC are making motors, and I can wait if they will offer what I want!
Got a hyper motor mount from Mike, and put a kyosho plastic 46t spur on the diff. The hacker 15l is just for packaging purposes, checking to see if the 46/13 gearing will allow the motor to clear the rear chassis support. It looks good, and I have a little room to go down to a 12t pinion if I need to.
Battery tray will be made from kydex, and placed in the gas tank location. I will most likely put the mmm behind it on that side, but need to weigh all of my components to get the best balance.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
04.27.2008, 08:47 PM
Can't wait to see this take off. Got the chassis for a good deal
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
04.27.2008, 10:39 PM
It was a good deal, got a bunch of spares with it, and 3 sets of tires/wheels. I have quie a bit of cleaning to do. Olny broken part is a rear lower arm, and I have a new one coming. I should have it ready by the time the MMM shows up! Hope that esc is good. I will run it at its rated max with motor brakes too!
gixxer
gixxer's Avatar
04.27.2008, 09:37 PM
I checked out the deals amain had on neu packs. Might have to check again since I thought the 6s was around $170.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
DRIFT_BUGGY
04.27.2008, 09:52 PM
I can't find neuenergy packs on amain?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
04.27.2008, 10:35 PM
They are all gone
DRIFT_BUGGY
04.27.2008, 10:45 PM
They are all gone
That explains why
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Takedown
WARNING: May become violent.
Takedown's Avatar
04.28.2008, 07:53 AM
Linc, this looks like it'll be a great build. Good luck!
RIP- Tammy (9/14/08)
brushlessboy16
brushlessboy16's Avatar
04.28.2008, 08:02 AM
if your going to run the mmm, why dont u get the castle neu?
04.28.2008, 09:42 AM
I am thinking about it, however I want a motor with a kv around 1700, and they say that the 2200kv model will be the first. I just won a hacker b50 11xl on ebay, so I will most likely run that for the time being.
brushlessboy16
04.28.2008, 09:46 AM
Ahh ok, i get it have you considered the KB series?
Cain
06.07.2008, 12:20 PM
how is this going?
azjc
06.07.2008, 12:43 PM
why bother cleaning?....its kinda like its June and the Xmas lights are still up on your house and you have thought about taking them down, but Xmas is only 6 months away and you hate to do double work......
06.08.2008, 03:08 AM
True, but I like to take em apart, so that I have a better understanding of how everything goes together. And I like to check diff fluids, and apply thread lock. So I might as well clean everything as well.
I need to post new pics, almost everything is back together. Just need to make up some mounts and trays...
big greg
06.08.2008, 03:19 AM
weird i like to do the same thing, that way when everything is together you can take off just exactly the part needed
