Batteries in Series Adapter
JThiessen
JThiessen's Avatar
Batteries in Series Adapter - 05.11.2008, 05:19 PM
I have a new 989 Superbrain, and currently a plethora of 3300 NiCd's. So I attempted to wire up an adapter to charge them in series. But it appears that I failed miserably. The charger doesnt show an error, but it certainly isnt charging the batt's.
Here is a photo of my adapter
[IMG][/IMG]
So what did I do wrong on it????
83gt
05.11.2008, 05:31 PM
looks right to me.
JThiessen
JThiessen's Avatar
05.11.2008, 05:36 PM
How can good news sound so bad?!?!?!
So something else must be going on. I hooked both batts up to it, and it just shows it cycling (yes, I changed it to 12 cells), the time laspe counter runs, and it continuously rotates through a few deifferent status displays (I dont know it well enough yet to say what they are). None of the fans kick on at all. I left one set run on it for about 4 hours, and they are basically dead still. I unhooked the batts and adaptor, connected one battery (changed it to 6 cell) and voila! Power supply fan kicks on, the meter shows it actually charging, and everything normal.
BTW, on the setting for Cut off Voltage, what should I be using? It shows "USED" and 1C, 2C 3C for options. SHould it be showing that for NiCd batteries?
Sammus
Sammus's Avatar
05.11.2008, 08:08 PM
have you taken a multimeter to it? making sure you have the expected voltage and polarity on the other end? If thats all fine and dandy then your connector aint the problem.
Duster_360
05.11.2008, 09:18 PM
^^^^ Def do that, get a pair of pacs that have voltage, check them alone so you know what each has. Connect the with your adapter and the voltage should be the sum of what you just measured. I built one looks a lot like yours and checked it this way to verify it gave me the sum of the 2 pacs voltage before I tried using it.
Sounds like you may have one leg switched??
JThiessen
JThiessen's Avatar
05.12.2008, 11:02 PM
Update: I measured each battery at 8.14V, connected them to the adaptor, and measured 16.28. So that tells me the adaptor is good. I tried adjusting the settings on the charger again, and actually got an error on it!
So I sent an email to Enerland (MRC), hopefully they can tell me what settings to put in on to charge them both. I've also searched these forums, RC Universe, RCTech, and RC Groups for a "settings" overview for the 989, but found nothing.
The batteries I charged individually ran great - seemed to have more punch than with my old charger (Vision Peak). Had a hard time keeping the front wheels on the ground!
JThiessen
JThiessen's Avatar
05.13.2008, 11:17 AM
'Nuther update: Email from Enerland.
You cannot select 1c or 2c but that is a reading of what the last few charges were and what capacity they reached.
Make sure that you have NiMH selected if they are 3300 mAh. Check the voltage display when you have your battery packs connected to see if you have the correct voltage. Since you have 12 cells you shouldn't see less than 12 volts. If this is a harness that you have made yourself then I would go back and check the soldering. Since both packs charge on their own I would have to take a guess that something is wrong with the adapter. You have the correct number of cells entered.
When you are doing a discharge then set your cut off V to 1.00. This will bring the voltage down in the battery to the correct level. That may help in trying to charge.
John
Wonder why they say I need to set it on Nimh for 3300's? That basically flies in the face of logic, and should be stated in the manual (IMHO). All in all, not a very helpful response.
Django
05.13.2008, 02:28 PM
I have this same problem with my Hyperion 0606i. Putting a meter on the adapter I see 14.4 volts out of the two 7 cell packs. Each pack charges fine separately.
My thread over at NK.
http://www.nitrokillers.com/showthread.php?t=1277
Post any updates please. I'll do the same.
