Kyosho & Tamiya Rock Crawlers -
05.13.2008, 02:30 AM
Tamiya & Kyosho are bringing out their own Rock Crawlers Tamiya:
Item No:58405
1/10 R/C Toyota Land Cruiser 40
1/10 R/C Car Series No.405
Brand new electric R/C crawler designed specifically to tackle tough, rocky courses. CR-01 chassis features durable aluminum ladder frame, excellent ground clearance, and ultra-flexible 4-link suspension. Massive new beadlock wheels and off-road tires with sidewall tread.
On RCZone they say the Kyosho uses a worm gear drive. If that's true, it will have unbelievable torque and holding power (since the main gear can't spin the worm gear, no coasting either). Should be an interesting gearbox
actually a worm gear can back drive.....iv done it
but oyur right on a rig like this, you can do some precision driving. But i really hope the casing is tough! cuz worm gears are rough on housing
I have a design for the axial crawler to use worm drive. I was going to use steel for the tubes and center section, mainly cause I can weld (and have a $1700 welder) plus they will be very sturdy, can be made more compact, and the weight is where crawlers need it, low. Also the steel parts should hold together better under the load of the worm. I will need some big bearings, and plan to offset the gears to alow for better servo mounting. Plan to use stock axial c hubs and knuckles. Axles may be custom, or I will integrate some sort of existing cvd axle.
Meet the Rock Force 2.2. Now anyone can discover what rock crawling is all about.
Starting with a worm-gear axle, the Rock Force 2.2 is packed with features such as special crawler motor and speed control amp. Incredible performance and design with options for disconnecting the rear drive (requires 3-channel R/C system), brings the fascination of rock crawling to everyone. Switch between drive, free and lock for user-friendly operation of various driving techniques.
Recommended as the best introduction to rock crawling, and for those who want to use this as the base machine to modify as far as desired.
Looking at those prices, these trucks are significantly cheaper here in Japan. I like both of them but I almost bought the Tamiya Land cruiser last weekend.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
They sell between $270-$300 here which is significantly lower than Tower's $354 price. I think I will buy a set or 2. I should have never sold my emaxx ESC .
Revo with OS .18TZ
