XT8 & MMM - 1st Impressions
Sower
Sower's Avatar
XT8 & MMM - 1st Impressions - 05.16.2008, 10:48 AM
Well, I got my MMM from Mike yesterday and got right to work. First I had to build a platform for the MMM and I did that out of CF as shown in the first pictures. Then soldered everything together before heading to the track - here's what it looked like:
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
Sower
Sower's Avatar
05.16.2008, 10:52 AM
So, after getting it all set up and programmed - we went to the track to test it out. The results were excellent. I'm running a 6s NeuEnergy pack and a Neu 1515 1100kv motor and it ran perfectly. My gearing doesn't allow for the 40mph speed I was after, but it got up to about 35 or so on the track. Still pretty good and easy to fix.
Now for the downside. After a few crashes here and there we heard something loose inside. Here's what we saw when we pulled it off the track:
I put it back together and even put a couple spots of super glue on it, but it kept happening. Last night I took it out and did a full bead of super glue around the contact points so I think it will work fine now - we'll see. Just something for you all to be aware of in your planning.
www.robsower.com
lutach
lutach's Avatar
05.16.2008, 11:19 AM
Your truck looks nice. A lot of people complain about ESC being in a bag and all, but sometimes it makes sense. I would've thought Castle would also secure it with screws so situations like this won't happen. When you run it again, wrap some electrical tape where the 2 halves of the case meet. A zip tie or Velcro would also work if you can get it under the ESC tray you have there.
Sower
Sower's Avatar
05.16.2008, 12:40 PM
Thanks - I have to say I love the XT8. It's way better than my old CRT. Turn in and handling are incredible.
And about the electrical tape or velcro, actually the base tray of the esc stayed put. It was the separation of the MMM casing that was the problem. Hopefully my superglue job on the casing last night will take care of it.
www.robsower.com
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
05.16.2008, 01:01 PM
glad to see it's finally worth the wait! speaking of waiting, i still don't have mine back yet for the conversion - but hope to soon. i bought the kit back in november 07.
i see you added the aluminum rear chassis brace - did you get a chance to run the stock brace first? just curious about how much it changes handling.
Eflite Blade 400 heli on 3s
Sower
Sower's Avatar
05.16.2008, 01:10 PM
Actually no - I bought it from a guy that had run it just a few times and it came with that as well as all of the other upgrades. Things like the aluminum hinge pins and captured conversion, aluminum uprights and steering blocks, hub extenders for 0 offset, and a few other nice touches. I love this truck!
www.robsower.com
lutach
lutach's Avatar
05.16.2008, 01:04 PM
I meant to say use the electrical tape on the Monster's casing to hold it together. Superglue works too .
DickyT
05.16.2008, 12:58 PM
Looks great! Glad to hear it is running well. If it continues to separate wrap a zip tie around it, it will not come off again.
If you look closely at this picture you can see the black zip tie I put around mine.
Sower
Sower's Avatar
Yeah, I suppose I could do that. However you would think that the casing would hold it's integrity together - more like the MM. I feel pretty good that the superglue will do the trick, but I'll keep you posted.
Thanks for the compliments!
www.robsower.com
Pdelcast
Pdelcast's Avatar
Why did you take the labels off? There are 8 snaps, but the label helps keep everything together in hard impacts...
Patrick del Castillo
President, Principle Engineer
Sower
Sower's Avatar
05.16.2008, 01:12 PM
Hey Patrick! Well, the reason I took it off was because the adhesive on the sticker and the texture of the plastic casing were not a comfortable fit for me. The sticker comes off very easily and I didn't feel it would be a good contact surface for holding down my investment.
See, I was going to use servo tape on the bottom of the MMM casing to the CF tray I built. And when I investigated the sticker that wrapped the bottom of the casing it wasn't a really firm adhesive. A bond is only as good as the surface it's applied to, and it just wasn't comfortable for me.
www.robsower.com
Pdelcast
Pdelcast's Avatar
05.16.2008, 01:49 PM
Hmm, that's not good... those labels should bond REALLY well to the polycarbonite case. I'll have production check to make sure there isn't any release agent on the cases we have in stock.
Sower
Sower's Avatar
05.16.2008, 01:54 PM
Yeah, I peeled mine off very easily and it left no adhesive on the plastic. Wasn't strong at all. Otherwise I would have no problem keeping it on there. I was worried that in warm weather it would get even worse. Anyway, thanks for being accessible here Patrick!
www.robsower.com
FG101C
05.18.2008, 03:03 AM
I had the same problem with my Sidewinder, I took the labels off because all the double sided tape I tried did not stick to the labels. I posted questions about this with no responses. I don't want to CA the two halves because if I have to send it in for repairs it will probably void my warranty on my Monster. Any other ideas Castle Engineers? Zip ties it is, and some strapping tape.
Pdelcast
Pdelcast's Avatar
05.18.2008, 11:36 AM
Zip ties work pretty well. :)
The Sidewinder labels weren't strong enough, so we changed the adhesive on newer Sidewinder labels and on the Monster labels. The new adhesive is supposed to work better.
Patrick
