Lipo C Question
Lipo C Question
DRIFT_BUGGY
Lipo C Question -
05.17.2008, 11:42 PM
If running a Neu 1512 2.5D which is rated at 78A, would running a 5000mah 25C (125A) be the same as running a 5000mah 20C (100A) because the motor is 78A?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
Visit DRIFT_BUGGY's homepage!
Find all posts by DRIFT_BUGGY
2
johnrobholmes
05.17.2008, 11:50 PM
You will get more punch out of the 25C packs, they should hold voltage under load better. This is assuming that both packs are rated correctly.
You will probably see some pretty big bursts from the motor though, it will be more than 78a.
---JRH---
11:51 PM
johnrobholmes
Find all posts by johnrobholmes
3
DRIFT_BUGGY
05.18.2008, 12:07 AM
Thanks for the reply, do the bursts vary on what gearing you are using?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
4
johnrobholmes
05.18.2008, 12:11 AM
Yes, and with vehicle weight, voltage, wire lengths, and battery temperature. Probably other factors I forgot.
---JRH---
johnrobholmes
5
Serum
05.18.2008, 03:11 AM
What packs are we talking about? it's not that a 25C puts out more voltage than a 15C pack.
Serum
Visit Serum's homepage!
Find all posts by Serum
Hybrid Mode
Switch to Threaded Mode
