what is this?
Revracer
Revracer's Avatar
what is this? - 05.26.2008, 06:45 PM
ok so what is this and is it worth getting? im using a mamba max in a revo and a little more punch could always be used. thanks in advance
http://cgi.ebay.com/Ultra-low-ESR-Hi...QQcmdZViewItem
MetalMan
MetalMan's Avatar
05.26.2008, 07:39 PM
It's a simple capacitor bank, with a huge price. You could buy some capacitors and wire yourself, and make something similar for only $5. It might not end up looking as pretty, but honestly $20 is way too much for something so simple.
lutach
lutach's Avatar
They are good. You could make your own as well and save a few bucks. Thos are the same that comes with the Hobbywing, Speed Passion GT and Venom 120A controllers.
jhautz
jhautz's Avatar
05.26.2008, 09:26 PM
So you have tried these? What is the voltage on the capacitors? 25V, 35V?
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
05.26.2008, 09:40 PM
No, the actual capacitor that came with my Hobbywing is the old single capacitor that later got replaced by that capacitor bank http://www.hobbywing.com/english/Art...?ArticleID=417. The caps are rated for 16V and it is meant for 11.1 volts which is what Revracer will be using with his MM and Mega. Like I said in my previous post, it will actually be cheaper to make your own. I will be making my own using axial capacitors to have them lay flat instead of making them tall with the radial caps. I'll be using big 1000uF, 50V caps just because I have them here with me.
Revracer
Revracer's Avatar
05.26.2008, 07:55 PM
could yall give me some links to everything i would need to make one? would it be worth having if im going to have a mamba max in a revo? thanks again
brushlessboy16
brushlessboy16's Avatar
05.26.2008, 08:01 PM
if you own some wire, and a soldering iron, all u need is the capacitors,
http://cgi.ebay.com/330uf-100v-Radia...QQcmdZViewItem
i made one, really easy to do...
Revracer
Revracer's Avatar
05.26.2008, 08:04 PM
how much will it help? if at all. and yeh i have some wire but its 12awg... and where would i attatch it to my esc?
brushlessboy16
05.26.2008, 08:20 PM
u can either solder it onto the power leads or do like me, run it inline with deans.
Desmo
05.26.2008, 09:09 PM
Do you have pictures?
The caps do need to be as close as posiable to the esc. I have 2 on these on my Novak 4.5 HV set up and it runs cooler than it did on just one.
http://www3.towerhobbies.com/cgi-bin...&I=LXKKN3&P=SM
Revracer
Revracer's Avatar
05.27.2008, 03:34 PM
so what all would i need? just some caps and wire? if i have a spare 470uf 16v cap(pulled it off an old esc when the esc crapped out. dont know if its still good...) would that be fine? what about the novak mega that is like 8200uf? or the 4700uf one. if i could make one for like $10 or so should i? and what do you mean run it in line with your deans? like solder it onto your battery connector?
Fkyx
05.27.2008, 04:14 PM
Inline means solder the appropriate connectors onto it so you can put it between your ESC and battery without replacing the connectors already on the battery and ESC.
lol
lutach
lutach's Avatar
05.27.2008, 04:27 PM
Actually all he needs to do is solder the cap leads together and if needed add some 12 or 14GA wire use some shrik wrap and from the caps to the ESC and the battery plugs where it originally goes. Please get a laugh at my crappy drawing.
Name:	Crappy drawing.jpg
brushlessboy16
05.27.2008, 04:18 PM
lutach
lutach's Avatar
Yes, great example right there.
