Disappointed with my new mega...should I be? -
06.16.2008, 11:48 PM
I was running a medusa 36-50-2200V2 with a 4S 5000mah in my rustler. I went from the stock vxl motor and esc on a 3S 4000mah and going to the medusa and 4S I noticed alot more runtime(atleast 40% more) and very cool temps. I figured more is better so I bought a mega 22/30/2 1770 with a 5S 4000mah. After running a few cycles and doing some speed runs geared 23/76 I had to stop alot to keep the thing from getting past 140 which I was told the max.
I then threw the 4S medusa combo back in to check the temps and they barely broke 100 most of the time I checked it was around 96(64 temp outside). I just don't get it to me the run time should have increased some and temps would still be cooler then my medusa. I could gear the medusa 30/76 and not have a problem and run cooler then the mega did on 23/76 gearing.
I'm not running a fan since I broke it but would prefer not to even run one. Now I'm thinking to just get a medusa 36-50-1600v2 and use this 6S 4000mah I have coming tomorrow.
The MM never even broke 100 anywhere on it; I do run a fan though.
Artur said I should be ok as long as I try to stay under 50amps constant and so many volts...sorry forgot the number but if I set my charger to 4.1 per cell that should give me enough margin. I doubt i'm the only one trying 6S on an MM but if I see white smoke I'll know why.
with the Medusa 1600 motor I would expect you to exceed 50 amps closer to 70-80 on 6s
I seen a post were a guy was going over 80mph(in a rustler) and pulling around 1100watts. I figure at 50 with 24 volts that's 1200watts so I might be ok. I'm starting to think that the mega just pulls more amps then the medusa and that's causing the higher temps. If I have time tomorrow I'll just gps both the mega and the medusa with the same gearing and see if there is any speed difference since they both have the same rpm(will really close). Just running both tonight it seemed the mega was abit faster but I'm not good at judging speed.
How is the timing on the MM? A 6 pole motor likes high timing to work efficiently. I had my Mega ACn22/30/2 in my MBX5T and with 14/48 it was running very good. I changed pinion to a 15 to test out a new ESC and the Mega was very hot, but after 7 minutes of hard running. I now have a FUN600-17, with the same 15/48 gearing and it gets very hot in about 2 minutes. The Mega is a power house and in a light vehicle you can get away with higher tooth count on your Rustler. In a heavier vehicle like mine, the proper gearing is recommended. A good tool to get is a data logger from Eagle Tree or BNB Products to see just how many AMPs your set up is giving you. Most of the time is just trial and error.
I just reread my first post and I didn't have it clear. I ran the mega on 5S with 23/76 and I ran the medusa 4S with the same gearing within an hour of each other tonight. Mega just ran hotter.
