Flightpower vs Thunder Power
david lamontagn
Flightpower vs Thunder Power - 06.24.2008, 03:01 AM
Is this both pack is as good one from the other??
I've a great deal on TP 5000mAh, 3s, 25C, extreme V2, but i know that FP is a very good pack.
is somebody here run TP pack?
azjc
06.24.2008, 03:04 AM
its the same company/same cells
david lamontagn
06.24.2008, 03:26 AM
OK that's what i thik.
The TP have the advantage that both "+" and "-" output lead exit on the same side.
Great advantage for the small e-revo batterie compartement.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.24.2008, 06:37 AM
I have some TP packs but have only ran them a few times, no dramas at all yet
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Sower
Sower's Avatar
06.24.2008, 12:37 PM
NeuEnergy has both wires coming out the same side too. So does Polyquest. I'm pretty sure both of them run Enerland cells as well. Can anyone confirm that for me?
I'm running a NeuEnergy now and it's great. Easily as good or better than my Flightpower was.
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
DRIFT_BUGGY
06.24.2008, 03:34 PM
I was going to give NeuEnergy ago before I got the TP but no-one had any 5S 5000 Neu's
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
rschoi_75
Certified Spaceball
rschoi_75's Avatar
06.24.2008, 01:17 PM
NeuEnergy, Polyquest, PolyRC, TP, FP, trakpower, and Hyperion all use enerland cells.
rcm xt8
rcm xb8
rcm crt.5
yuri
yuri's Avatar
06.24.2008, 03:36 PM
And what kind of cells is TrueRC using?
bruce750i
bruce750i's Avatar
06.24.2008, 05:26 PM
I bought two 3s Fp one came with both wires out one side and the other had one wire out each side..?? Awkward!!
david lamontagn
06.24.2008, 05:57 PM
speedracer1129
06.26.2008, 08:56 AM
Flight Power has stopped producing the "known" split wiring configuration and is now producing their packs with the wires coming out on the same side.
david lamontagn
06.26.2008, 12:39 PM
Very good upgrade from FP
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.24.2008, 06:59 PM
David,
I am thinking of using the same batts on my E-Revo TP 5000 mAh 3s. You always seem a couple of thoughts ahead of me :)
david lamontagn
06.24.2008, 07:06 PM
Originally Posted by mkrusedc View Post
David,
Ya your right!!!
My e-revo is order today, and tonight i'll order 2 x TP 5000mAh, 3s.
With my Neu 2.5d, i'll hop that this truck will moove his ass
VintageMA
VintageMA's Avatar
06.24.2008, 08:35 PM
I am already running the TP 5000mAh 3S packs in my E-Revo and you are going to love them.
Probably the biggest pack that will fit reasonably and I only dumped 2200mAh in 15 running hard with a 1515 3d (overgeared a bit too as I only had a 24T pinion at first).
“Everyone has a right to be stupid; some people just abuse the privilege.”
