Race Upgrades For Matrix TR "FRE"
Takedown
WARNING: May become violent.
Takedown's Avatar
Race Upgrades For Matrix TR "FRE" - 07.02.2008, 10:06 PM
Well I figure that Ill have around $250 at the end of next week sometime and I am about to make a list for my Cen Matrix TR Arena FRE truggy. Ive decided that Im gonna put the purchase of buying a neu motor on hold yet again. Remember this setup is for racing. Heres what I had in mind.
ESC- Modded MM "Already installed" Possibly a MMM
Motor- Align 600xl "Positive this is what I want"
Lipo- Flightpower 3200mah 5s 30-60c "Will be getting 5s 5000mah TP or FP soon"
Cap Board- (8) 330uf 50v caps. "For cooling"
BEC- CC BEC
Servo- Hitec 5645mg Digital Ultra Torque "Already installed"
Radio- Futaba 3pm FM "Already have"
I would like to know what other upgrades would you reccomend for this? I plan to run long 10-15min mains. What gearing would be optimal? Thanks
RIP- Tammy (9/14/08)
Takedown
Takedown's Avatar
07.03.2008, 01:37 AM
Ok here is some pics...
Takedown
Takedown's Avatar
07.03.2008, 09:29 AM
I just cleaned her up today and all that mud and dirt are off the cvd's, chassis, towers and cambers. Ill see if I can take a few more pics later today.
brushlessboy16
brushlessboy16's Avatar
07.03.2008, 09:39 AM
get some 40 series :D
Takedown
Takedown's Avatar
07.03.2008, 09:51 AM
I was thinking of 40 series but I can only find 17mm hubs. I need 23...
brushlessboy16
07.03.2008, 10:48 AM
so u can get 40series... u dont need to get hubs
brushlessboy16
07.03.2008, 10:22 AM
according to cen, the Matrix Tr should come with 23's
07.03.2008, 10:29 AM
These are the 23mm 40 series
http://www.pro-lineracing.com/p-347-...s-23mm-hd.aspx
Takedown
Takedown's Avatar
07.03.2008, 10:32 AM
Yes, ben they do come with 23mm hex rims. Arct1k- I was looking at those and thats most likely what Im gonna get.
Takedown
Takedown's Avatar
07.03.2008, 10:54 AM
IDK ben... Ive heard using 40series for racing is bad.
skellyo
skellyo's Avatar
07.03.2008, 12:23 PM
Yes, I've heard the same. The 40 series are typically wider and heavier than most other tire/wheel combos. I think the big push now from most folks is to go to LPR style tires/wheels.
cornolio
cornolio's Avatar
07.03.2008, 01:03 PM
nice truck.do you know the diff gear ratio of the tr?i cant find it anywhere.
xray xt8 MMM neu1515 1y
hotbodies ve8 novak HV 6.5
hotbodies cyclone tc
mugen mtx4(nitro)
lst2(conversion ongoing)
  Send a message via Yahoo to cornolio
brushlessboy16
07.03.2008, 01:10 PM
9/26 is what i read, uses the same gears as the Gst 7.7
cornolio
cornolio's Avatar
07.03.2008, 01:24 PM
thats what it says on the manual.but i think its wrong coz when i put it on the speed calculator,it says ill go 5mph.i already ran it wit a neu and it went at least 40mph.
mugen mtx4(nitro)
jhautz
jhautz's Avatar
07.03.2008, 01:27 PM
No the Artena uses 13/38 difs. Thr RTR Buggy uses 9/28 and the FRE Buggy uses 13/38 also. CEN uses some wierd ratios and different all over the board.
I personally would upgrade the difs with the Hotbodies truggy difs. 10/43 and then change the center spur to a 46T. The stock 66T forces you to push the battery way off to the side just because of how big the spur diameter is. Use the Cen buggy center spur.
Also, a must do upgrade is the upper arm of the servo saver. the stock plastic ones break easilly. The CNC red is the solution. I have one sitting here new in the package if you are interested. I'll give you a deal on it LMK. I bought it for a CEN I had and then sold it before installing it. My other 2 cens were already upgraded so it sat in my parts bin for the last year.
to make it...
or break it...
Silent...But Deadly
