Anyone ran 6S in the New E Revo yet?
sikeston34m
sikeston34m's Avatar
Anyone ran 6S in the New E Revo yet? - 07.05.2008, 12:53 AM
Has anyone ran 6S in the New E Revo yet?
I'm wondering how everything is going to hold up, and also if there is any steel cvd's that will fit the center drives yet?
If you have ran 6S, please describe your setup. (Motor, Batts, ESC, additional mods, etc.)
Thanks
marcus
marcus's Avatar
07.05.2008, 01:23 AM
I'd be more interested to know how they got 6S pack/s onto the E-Revo without making it look like Frankensteins Monster as well. :-)
Larrydino
Larrydino's Avatar
07.05.2008, 07:14 AM
you can fit some 3s 5000's by maxamps
azjc
07.05.2008, 09:43 AM
Flightpower 5000 3s also fit
ReV:-O
RC-Monster Carbon Fibre
08.17.2008, 09:09 PM
dont you mean the 4900 3s packs? if so, they are 30mm tall - will they fit?
e-mike
e-mike's Avatar
08.17.2008, 09:45 PM
me too i run 6 cell(4800mah 25c zippy-r) in my bleu e-revo with a 1515 1.5d wow50mph on weelies for a 30 min of fun!!!!
D8t on juice!!
gixxer
gixxer's Avatar
07.05.2008, 09:41 AM
Not yet but hopefully in the next couple of days. I would of had it done already but the first set I ordered were to tight of a fit for me.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
azjc
07.05.2008, 09:46 AM
Thanks
in my converted 3.3 Revo I am running a Neu 2.5d on 6s and I still have the stock tranny to diff lines and drivelines and everything is hoding up fine, if you stay away from the sudden WOT from a standstill you will be fine
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
07.05.2008, 10:02 AM
6s would be cool, heck, im still trying to figure out gearing......but i guess it's kinda hard to do..since i don't have it, but from the info i have gathered,...running the following
7xl
quark 125b
2s2p (4s) 8000 maxamps packs
badland tires
the gearing should be fine at 22/68
i checked this on brian's calc. as well....., but on another note...can't wait for results on the 6s
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
sikeston34m
07.07.2008, 09:35 PM
Well I just ran my E Revo on 6S. Wow, what a different truck.
I've been used to running the E maxx. This is definately a horse of a different color.
I installed a Century 600 Outrunner that I custom wound to a 4 turn wye wind. This motor was originally 715kv, but now I can only guess what the kv is. It spins a 25 tooth Mod 1 pinion and meshes with a 38 tooth Nitro Revo spur that is a perfect mount to the slipper.
Firepower 6S 5000mah 20C is feeding the spark to a Quark Monster Pro 125 amp ESC. Mods include a HV Novak Cap along with a CC BEC.
The setup has loads of power. Alot of instant acceleration and tops out in the 45mph range. Wheelies at speed are pretty easy on a surface the Talons will grip. This Motor runs hotter than I prefer, so I might come up with another power plant or change the setup somehow.
The Talons by the way, turn into saucers on loose gravel, just by grabbing Throttle.
One of the Front Tires had a come apart. It appears the glue let go. Now I've got the stuffing hanging out one side. LOL
What a loose suspension! I can tell there's alot of tuning to be done. Getting stopped from 45mph is a wobbly back and forth challenge. The suspension is way too loose. Stiffer springs may fix most of this.
I think one of the single biggest improvements this setup will see, is the Monster Mamba. One should be coming my way soon.
kevin23
07.08.2008, 07:21 AM
I have been running my e-revo for a couple weeks now,still brushed though,and it is great,I went up a step in spring rate front and rear,added the sway bars.Totally different truck,I ran in the truggy class this week and lapped everbody in the 10 min main.I can't wait for the brushless,I am waiting for the mmm like everyone else.
I will be running the axi outrunner you have in your emaxx,the 8 turn.I have the cc bec,the novak cap,and the fan.
I will run this setup on 2 2s 5000mah 20c packs,what kind of runtime would you expect from this setup racing on a track?Wondering if I need higher mah to run the longer mains?
sikeston34m
07.08.2008, 08:04 AM
I run the same Packs and get 25 to 30 minutes of hard runtime.
You should be fine.
Sammus
Sammus's Avatar
07.08.2008, 10:20 AM
sik, not sure why you would be worried about the stock shafts, I've never seen a broken revo shaft, I think those plastic splined shafts are the best. I think that tiny bit of torsional flex also takes a lot of load of the diffs too, which can only be a good thing when its that pesky little 4 gear job :P
gixxer
gixxer's Avatar
07.08.2008, 10:48 AM
Just got in my batteries yesterday and ran 6s on a 1515 3d last night. :) Will play with the punch control and try running it again today.
bruce750i
bruce750i's Avatar
07.08.2008, 06:03 PM
Yep 2s3p FP3700's / MMM / Tekneu 2.5df 22/65 on badlands. I have my slipper on the loose side so i don't have much stress on the drive train. It's the same studly revo-spec drive train thats been in the revo3.3, 2.5 Snapped a front a-arm already tho. Went looking for rpm front arms and came home with the true-track rpm rear arms and another stock front arm(LHS didn't have both lefty and righty rpm front arms)
