MRC Baja King what bl setup should i use?
Thunderbruiser
Thunderbruiser's Avatar
MRC Baja King what bl setup should i use? - 10.04.2005, 03:18 AM
I have a nice MRC baja king that i want to setup for bl and am going to run 12 cells.....i was wondering what would be a good motor i want a mix of torque and speed but don't wanna kill the tranny lol....I was looking a feiago 8l or so....lmk guys thanks
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.04.2005, 10:26 PM
Welcome to the forums, Thunderbruiser. The baja king will work quite well with the 8L, 9L, 10L or even the 7xl motors. I think I would use a 9L myself. It offers a nice balance of power and runtime.
Thunderbruiser
10.04.2005, 10:41 PM
thanks,
and the 9L is ok on 12 cells? cause that's what is gonna be my main power source
garage:
nitrostarter
nitrostarter's Avatar
10.04.2005, 10:49 PM
Sure! The 9L is great on 12-14 cells.
N. Rustler conversion
RC-Monster Mike
Site Owner
10.04.2005, 10:50 PM
You will be pleased with the performance.
Thunderbruiser
10.04.2005, 11:12 PM
cool you guys have ebay auctions correct? cause if so i'll prolly pick one up from ebay in about a week or so...also would the schulze 18.61 i believe it's called be a good speedo or should i got for an mgm?
garage:
Dafni
Dafni's Avatar
10.05.2005, 01:31 AM
Hi
for the 9L I would strongly suggest a BK Warrior 9920. They are currently out of stock, but Mike will get them in.
They have a nice price tag and can take a beating.
Thunderbruiser
10.05.2005, 05:22 AM
thanks
garage:
RC-Monster Mike
Site Owner
10.05.2005, 09:31 PM
The warriors should be in stock by the middle of next week! Finally!
Yes, there is also an E-Bay store - RC-Monster Hobbies
Thunderbruiser
10.05.2005, 11:04 PM
cool i hope to get em next week...got a savage and maxx to pay for
garage:
Thunderbruiser
10.26.2005, 04:45 PM
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
would this be ok? i only won it cause it's cheap and have heard good things in the past about them....this will be used until i get the proper setup with warrior bk
garage:
RC-Monster Mike
Site Owner
10.26.2005, 06:06 PM
Not for th thunder king! Simply not enough and would probably blow up in no time.
Thunderbruiser
10.26.2005, 06:17 PM
Virtual Test Stand Inputs
Open Circuit Voltage 1.25 Volts X 12 Cells = 15.00 Volts
Battery Resistance 0.0045 Ohms X 12 Cells = 0.0540 Ohms
Speed Controller Resistance = 0.010 Ohms
Motor Type 27/26/4
Motor, Unloaded 1172 RPM/Volt
Motor Resistance 0.096 Ohms
Motor no-load current 0.75 Amps Prop Type Thin Folding Prop
Propeller Constant 1.18
Diameter 6.0 Inches
Pitch 3.0 Inches
Gearbox Other Gearbox Ratio
Gear Box Ratio 1.00 :1
Virtual Test Stand Outputs
Prop RPM: 16355 RPM
Current: 6.5 Amps
Voltage into Motor: 14.6 Volts
Power Input: 95 Watts
Power Output: 81 Watts
Efficiency of Motor Only: 84.7%
Current at Max Motor Efficiency: 10.7 Amps
Pitch Speed: 46 mph
Thrust at Pitch Speed: 14 oz
here are the stats....and um really? why the truck is just too big or what?
are any of those stats good?
garage:
RC-Monster Mike
Site Owner
10.26.2005, 06:26 PM
The truck is too big. Those specs suggest that it is most efficient at 10 amps, which is not even close to what you need. 12 cells times 10 amps is similar power to a 27 turn stock motor, which will be a slug in your big truck.
Thunderbruiser
10.26.2005, 08:30 PM
haha so i need a more powerful draw motor that sucks....so i basically wasted $80 some buck i;'ll just relist it after receiveing
garage:
