Emaxx Wheel Adapters
cimarrone
Emaxx Wheel Adapters - 10.08.2005, 09:54 PM
Have a wheel adapter ?.
I just finished building my 95% all alum Emaxx up from a gorillla max chassis. I'm running the Novak HV maxx BL setup. I bought some 40 series Proline Road Rage tires and bead lock rims to try and stick the truck to the pavement. I got the rims today an noticed they are 23MM and not 14mm like the stock Emaxx. Any good suggestions for any adapters ? I found these, Are they any good.
http://www.crazynutracing.com/produc...13816a92b595bb
poconoblmaxx
poconoblmaxx's Avatar
10.08.2005, 10:34 PM
Never used the crazynut adapters but I have used these adapters .
Shadow350Z
Shadow350Z's Avatar
10.08.2005, 11:15 PM
those r proline rims rights?
then go with proline 23mm adapters or go to the UE site and they lso have 23mm adapters
  Send a message via AIM to Shadow350Z
mt_enthusiast
mt_enthusiast's Avatar
10.09.2005, 12:42 AM
RCM Mike has the Dace adapters too. The Dace uses 22mm or 7/8" sockets whereas the Proline's need a 23mm wrench which you may need to buy from Proline as well. I have the Dace adapters, and they are pretty nice. I bought Dace because of advice from other RCM forum members. No regrets!
EDIT: the Dace adapters are available in black or blue.
  Send a message via Yahoo to mt_enthusiast
Serum
Serum's Avatar
10.09.2005, 03:34 AM
For the 10 dollars in price difference i would get the Dace adaptors..
They look so much better, plus i don't like the idea that the aluminum ring is held by only the small bolt. at a side impact it's more likely that the shaft will snap. the stress that's directly on the thread is larger.
coolhandcountry
coolhandcountry's Avatar
10.09.2005, 08:18 AM
You kind of lost me with that small bolt serum.
I have ran both the 23mm adapters. I have the proline and the dace. The dace seem to stay tight better. The washer around the outside seems to hold better. The dace will alsot fit the ue cvds as the proline will not.
My vote goes to dace.
standard_63
standard_63's Avatar
10.09.2005, 10:18 AM
I like the Dace adapters as well, I have 2 sets -- one on my Revo and one on my Emaxx. They look and work great and fit right over the stock hex. Mike sells them in the new stuff section.
Re: Emaxx Wheel Adapters
mt_enthusiast
Re: Emaxx Wheel Adapters - 10.09.2005, 10:50 AM
Looking at those adapters, my guess is that they wouldn't be as good as the Prolines. They use the same drive method where the 23mm hex is driven by the pin through the axle. The fact that they use the same stock axle nut to hold them on is weak IMO. I think this drive pin is what Serum was referring to coolhand.
As coolhandcountry said, the Dace will work with many CVDs or even the stock sliders because the Dace fits over the 14mm nut. The adapters you linked or the Proline will only work with shafts that have the pin through the axle. UE drive axles have flats to drive the 14mm nut instead of a pin through them. So if you are running UE CVDs or plan to, I'd say the only way to go is Dace.
Serum
Serum's Avatar
10.09.2005, 12:33 PM
No, the drivepin is nice! in fact, it's great. It is 7075 aluminum and will not deform faster than 6061 hexes.
It's the M5 bolt that gets more stress to it than with the proline/daces. (it's because of the large ring that needs to hold it tight.)
mt_enthusiast
10.09.2005, 12:45 PM
I don't know what you are referring to as the drive pin then if it isn't part of what comes with the Dace assembly.
Serum
Serum's Avatar
10.09.2005, 12:57 PM
I misunderstood you. i thought you said the drivepin was a weak point of those 23mm hexes, though this drivepin construction is strong. But that was not what you meant. You are refering to the M5 nut.
But what this all started about was what I meant as the M5 nut. the stress on the M5 nut is much bigger with those large rings with a sideimpact on the wheels (the rings that hold the wheel to the 23mm hex)
Got it? :)
mt_enthusiast
10.10.2005, 07:28 PM
yep....got it. :L: I tried responding yesterday, but the web site didn't seem to work at the time.
Gundam-Guy
Gundam-Guy's Avatar
02.11.2007, 06:24 PM
has any one ever tryed the INTEGY 23MM ADAPTERS are they any good?
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.12.2007, 04:08 AM
i'd stay away from integy alu parts.
they are weak.
losi 8ight-t
xray xt8
