Originally Posted by hoovhartid
yeah.
I guess my main point was to see if all 4 tires were giving the same about of torque under load. I suggest putting the truck up on something with the wheels suspended(free to spin). While the trigger is being pulled (lightly...if you are by yourself you can try to turn up your throttle on your transmitter till the wheels just start to spin)anyway--if one wheel is easier to stop than the other three, then that is the wheel that is spinning slower and causing you to veer off under throttle.
by the way..don't hold the wheels so tight that you break anything...i merely meant for you to find a part that may already be broken
just checked. all four giving same power. plus i just realized it cant be one tire not spinning as fast, cus if that was the case, it prolly would veer off to the same side everytime, but its actually random. and say if it was to veer off to the right, when i turn left on my remote and i mean just a little bit, instead of centering out like it should, now my truck would veer off to the left...sooo annoying! impossible to drive pretty much, but at low speeds it does not do this. and if it does veer off at low speeds i can just counter turn and itll center out.
brian- im pretty sure its at high speeds and not at the amount of throttle i apply. because if i applied a good amount of throttle from the start, my truck will wheelie and take off but itll still go fairly straight. i think its more of as the truck is going in higher speeds.
you maybe right about the toe in/camber but i had it running straight before. and i wasnt even accurate with my toe in/camber..i just eyed it.
but now, i made sure theres the same amount of thread showing on both sides so its pretty accurate.
and the front tires are even more toe in now so i thought that would help but nope. i mean i can try toeing them in like a crazy amount but the fact is, i didnt need toe in before so i know it doesnt need it. i mean worse comes to worse ill just toe in like 5 degrees haha. and still im not even sure if thatll fix my problem.
