Originally Posted by suicideneil
Is that a revo or hover mower?
Clever idea with the cooling box yeah, bet that fan shifts some serious air...
It will draw smoke off of a cigarette at 3 to 4 inches and all the openings have filter grade foam stuffed in but it only draws .18 amps and I got a 31 min run time in grass. The g10 plates will also serve as a roll bar when I install the single motor plate and it also stiffens up the plastic chassis in the center. I had a non stop 31 minutes freak out bash session with GRP Grips in grass in 85 degree heat with many roll overs wheel stands and other various stupidity, no failures no missing foam no breakage and every thing was between 115 and 117. It was the first time I have run it to voltage cut off. The fan is light, the box is light and every thing inside was sqeaky clean. Not bad for a 1512 2d/f neu on an MM with 4s(twin maxamps 5000's)
