I was going to get this servo but i saw on the traxxas forums that you need to set the end points on it otherwise it will burn out. Is this right? I only have the stock radio and reciever so i cant change the end points.
You could also adjust the linkage so the throw of the servo is minimized. Any servo will burn out if it is forced to push against an immovable object for extended periods.
