I cant figure out where to put that thing. The controller is air tight. I cant find 3 holes on the controller to insert that thing into? Can anyone help? thanks.
You should have a usb cable that plugs in one end (mini usb goes to the CL), and then the 3 pins plug into the Rx lead coming from the esc- you have to unplug it from the actual Rx.
It's still the same as the old one. They just removed the connector coming straingt out of that thing. There's also a marking on those indicating +, -, and signal.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
