overpower
tyrewq
overpower - 11.17.2005, 09:18 PM
hi, what happens if you apply 20 cell power to a feigo 8L (max 14 cell) motor? does it just heat up or will get broken somehow?
coolhandcountry
coolhandcountry's Avatar
11.17.2005, 10:08 PM
I not sure on 20. I have seen one on 18 cells. It screams. It is peepy.
Peace!
Country
Help support the
Rc-Monster
Buy here
tyrewq
11.17.2005, 10:39 PM
i'll be trying it after my batts arrive. if it breaks i'll replace it with7xl
squeeforever
squeeforever's Avatar
11.17.2005, 11:17 PM
i wouldnt even attempt it. it willl most likely overheat and thermal if it doesnt just fly apart from to many rpms.
squeeforever
11.17.2005, 11:22 PM
so your gonna run 20 cells on a 7xl? i would recommend a 8 or 9xl if thats the case.
tyrewq
11.17.2005, 11:52 PM
specs say 7xl could handle 16, the 8 could handle 14. guess 7xl got higher torque?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.17.2005, 11:56 PM
For sure the 7xl has higher torque. Be careful if you over cell these motors. If it draws too much power, it will damage your speed controller. The 8L could handle some high voltage for a bit, but it is far from ideal. If you want the power of 20 cells, get a motor that can handle it(as sguee mentioned, the 8xl or even better, the 9xl).
tyrewq
11.18.2005, 12:12 AM
man, i wish there's a mini transformer that i could plug in there so it will convert the 20 cell voltage to 14 cell but runs longer because it's 20. kinda like the volume units on radios.
Serum
Serum's Avatar
11.18.2005, 04:07 AM
Possible.. just limit your esc on the transmitter. that is the best way to do so..
but that motor is way too hot for 20 cells..!! it will reach a very un-efficient state, and it will get burned or the controller will die because of the high current it takes.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.18.2005, 07:43 AM
one word...DONT
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
tyrewq
11.19.2005, 02:21 AM
i've just removed the 8L and installed the 7XL and added a taller pinion. it seems to accelerate faster, and when i rev it up at the work bench the chassis seems to hum at 14 cells :)
can't wait for my additional cells to arrive
it also took me 2 hours to connect new deans to the motor :( . is there a solderless clamp type alternative to deans?
Serum
Serum's Avatar
11.19.2005, 09:09 AM
you use deans between the speedo and the motor?
tyrewq
11.19.2005, 09:54 AM
it was originnally designed with deans everywhere
Serum
Serum's Avatar
11.19.2005, 10:15 AM
how does it use the deans then? one for each of the three wires?
tyrewq
11.19.2005, 10:19 AM
yup
