Brushed motor wiring questions
Brushed motor wiring questions - 10.21.2008, 02:00 AM
Ok, so I have an "interesting project" and for cost reasons would like to run a pair of brushed motors. Looking at a pair of the kershaw designs 700HO motors and was wondering how to wire them up.
I plan to use a MM and a pair of 2s lipos, wired in series for 4s. Would i wire the motors in series, or parallel?
From what I can gather I want to run them in parallel to get the full 14.8v to each of them. If I run them in series they will only "see" half of the voltage on each motor? This is how I understand it, but please correct me if I am wrong. This truck will not be geared very high, and will have a 2 speed tranny as well. It should weight about 12-14lbs, and have alot of traction! I also would like brushed for the very smooth low speed response, which sensorless just can't seem to match.
10.21.2008, 08:04 AM
You have it right - Series for 7.4 on each or parrallel for both getting 14.8...
Motors are effectively just resistors - in series you will get 1/2 the voltage dropped across each assuming they have the same resistance.
10.21.2008, 11:15 AM
Thanks Chris, I thought I had it right but wanted to make sure. I just found some johnson 550 motors, so I may try them out and see how they do before I drop a bunch of money on the 700 motors. I am cheap sometimes...
If I wired the motors in series they would only go half as fast as they would wired parallel. This may be better as I am going for slow speed with good throttle control. 20mph in 2nd gear is plenty for this project.
Does anyone have any idea what kv the traxxas titan 23 motors are?? I figured they are around 1500kv, but not sure.
Or would it be better to wire them in parallel and just vary the input voltage? I will be using a pair of 2s packs, and can wire them in series or parallel.
Tempted
RCM is smarter than me....
Tempted's Avatar
10.21.2008, 02:25 PM
You might give it a little while and try the Traxxas 750 motors in the Summit. They should be considerably cheaper than the stuff Kershaw sells and I think they will bolt up to a stock motor plate.
The answer is no. And yes, mine is faster.
10.21.2008, 05:58 PM
They might have a 25mm bolt pattern, but I think they have the 30mm pattern. Remember that the rear facing mount on the revo has both 25mm and 30mm bolt patterns. Plus most 700 motors use the 30mm pattern and also use m4 thread screws. I am sure that they are heavy buggers.
I will try the johnson motors I have. I will wire them in series first and run them on 4s lipo.
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.21.2008, 05:21 PM
The Titans I believe are 1450-1500 IIRC.
Tower has an ofna 775 motor 10 bucks cheaper than kershaw.
http://www3.towerhobbies.com/cgi-bin...?&I=LXVCL4&P=7
www.cubicle101.com
Tempted
Tempted's Avatar
10.21.2008, 05:26 PM
Is it a removable pinion? And its meant for a starter, will it hold up after it gets hot?
10.21.2008, 08:23 PM
I believe the 700 series motors have a 30mm mounting pattern, hence the special mount that Kershaw sells for his 700HOs. You can modify the stock mount, or just buy the mount from kershaw, or even make your own easily enough. As for motor options:
http://banebots.com/pc/MOTOR-BRUSH/M2-RS775-144
1205kv, ideal for slower speeds if ran on 4s lipo.
lydiasdad
10.21.2008, 11:22 PM
best brushed motors. I have had the 18 volt dewalt for a while. It spikes at 1900 watts on 6s2p a123 cells. They are also long lived at those high voltages and the brushes are removeable. I even ran my 18 volt motor on 8s a123. very powerful (brushed) motors.
10.22.2008, 10:39 AM
Any chance you could link me to one of those Dewalt motors?
10.22.2008, 10:43 AM
Thanks for the link Neil. I may just buy two of those...
10.22.2008, 10:52 AM
Ok, time for another question about sereis and parallel wiring...
Would it be better to wire my batts in series for 4s, and then parallel the motors for lower rpm, or wire the batts in parallel for 2s and wire the motors in series? The only thing I can think is that the current draw thru the esc will be higher on 2s than 4s. I plan to use a MM with a ccbec.
Will either wiring method produce any more power or torque? I guess that I will just have to experiment both ways. The motors that Neil linked to look great, and their kv on 4s with my proposed gearing would be almost perfect.
TexasSP
TexasSP's Avatar
10.22.2008, 11:13 AM
Should work the same both ways and pull the same amps both ways. Either way the motor sees 7.4v and pulls the amps it needs. I think at this point I would wire it which ever way is easiest for you.
www.cubicle101.com
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
10.22.2008, 11:20 AM
I'd suggest paralleling the motors, and running 4S. Unlike brushless motors, with half the voltage going to the motors in series, you'll also get considerably less torque as they can't just pull all the current in the world to make up for the low voltage (like BL); I learnt a lot about brushed motors way back when I was running brushed setups in my old Wild Dagger. If you want lower RPMs, I'd just gear down personally. On 4S, you'll be running them at their most efficient too.
The MM should be able to handle them easily in High-Power FWD-only mode, but might have a bit of a hard-time in reversable mode (at a guess). Just my 0.2
10.22.2008, 11:30 AM
Thanks for the info. I figured that I would wire them parallel and just run 4s thru the MM. I will be in fwd/rev mode, so hopefully the higher voltage will help the esc survive. Considering I will be gearing for around 10mph in 1st and 15mph in 2nd I do not see the MM having any issues...
