Castle 2200 on 4s or 6s -
10.23.2008, 08:14 AM
So me and a couple others are having a little debate over which would be better with the Castle motor.I would love to hear what someone from Castle,and others has to say about it.IMO 6s puts the motor to high in the RPM range for everyday bashing.For occasional speed runs it should do good on 6s, but 50000 rpms seem to high for every day bashing.Since I have no Neu,are they happy in the 50000 rpm range?Actually it would seem to me like 5s would probably do good,maybe the sweet spot?But still a little high?
10.23.2008, 09:08 AM
I ran the NEU 1515 1Y on both 4S and 6S yesterday...
You are right in that it pushes the RPM to the upper end of the motor specs.
4S is around 35-40K which would be a sweet spot IMO. Geared at 22/56 on 4S puts you in the mid 40s for speed. 6S puts you at about 60MPH with still a LOT of torque to lift the front end up and over even while already moving at 40MPHish. Hitting the throttle of 6S from a stop would either burn up the slipper rather quickly, tear up your tires rather quickly, or tear up the drivetrain quickly. So, even if you geared for slower speeds, the torque increase will just be too undriveable.
10.23.2008, 09:15 AM
Sounds good though!
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
Supermaxx
10.23.2008, 09:38 AM
I always get standing forward or backward flips when I blip the throttle  . My slipper is still intact but I did snapped an output shaft on my gmaxx tranny before.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
KillaHurtz
10.23.2008, 10:44 AM
I think its really about he power level you want. 4S is good power, BB nitro-like speeds with more TQ and accel. Very drivable and reasonable on the drivelines.
6S on a 1Y is like an A-bomb. Over the top power and likely to cause a driveline meltdown if left in the wrong hands. Extreme care is advised.
So it comes down to what you want. If 45mph is fine, and looking for trackable speeds, then go w/ 4S. If you want a out of control driveline shredding wheelie monster, then go all out on 6S.
10.23.2008, 10:48 AM
Plus if you have it geared for 60mph on 6s you will need good lipos to do it. I would say that enerland 6000 25c cells would be best, or a pair of smaller 6s packs in parallel. Maxamps users need not apply here...
Most have great success with the 1y on 4s. I have a 1.5d on 4s and it is a bit much. I keep gearing it up and it never really gets hot, but the lipos are getting warm. I would like to pick up a 1y and see how it does. For 40-45mph in a MT I think it would be just fine...
10.23.2008, 11:45 AM
I fully agree. The 1Y is much better on 4S and seems to run stone solid with great temps.
My only reason for pushing 6S was to just push in the MMM. 60 in that thing is dang near flight lift off. Phaltlines are now pretty much unglued, the Slipper smoked a little, so I know it's a recipe for destruction.
10.23.2008, 11:13 AM
I'm using the CC 1Y on 4s in the truggy (hyper ST) for racing but am just about to swap out tonight the 2.5D for another CC 1Y into my G3R on 6s2p A123 for bashing.
I already upgraded the Diff to hybrids so I think the input shaft will be the weak link...
10.27.2008, 05:18 PM
I havent read the whole thread yet, but how did this work out for you? Or did your shaft issue put the brakes on it?
I'm really curious how your shocks are going to hold up with those batteries. Mine sagged like cows teat at milking time......
Clinically Inane
10.23.2008, 12:17 PM
Great thread! All of the responses so far are spot on.
One of the things we do at Castle Creations is answer the question "What is too much power." We can’t seem help ourselves. The 1515/1Y Neu or our 2200 Kv motor (same basic motor) on 6s, IMHO, is an example of too much power. It is a car breaker and uncontrollable in anything but a straight line. While it will break cars, the power system will survive. These motors are rated to 60,000 RPM. The RPM the motor will reach on 6s will not damage or degrade the motor, just the car. I do not find 6s very much fun; in fact it feels like standing in a large parking lot shredding $100.00 bills. It is too much or just plain stupid power.
4s on the 2200 is the sweet spot. It is drivable, race-able and will eat Nitro for lunch. It is just plain fun and makes you giggle as you drive.
Our 2650 is actually a Neu 1512/1Y not the 1.5D. The Neu 1512/1.5D is a 3300 Kv motor, which will be a monster on 4s and needs really good batteries as it will pull massive amount of amps. Our 2650 is for lighter 1/8th scale buggies and IMHO is a handful on 4s. It is, however, capable of 6s as long as you have some expendable cash and the wrenching time.
Important note: When running a Neu D wind motor set your ‘Motor Timing’ in the ESC to ‘Lowest.’ According to Steve Neu these motors don’t respond to timing but with higher settings can cause battery and ESC problems.
Bernie
10.23.2008, 12:53 PM
Originally Posted by Bernie Wolfard
Great thread! All if the responses so far are spot on.
Bernie
I was actually standing inthat very parking let yesterday!
I don't understand, but I don't think I like it.
10.23.2008, 04:43 PM
Bernie
Does he have any recommendations for the Y wind motors?
10.23.2008, 04:50 PM
i run my 1y on 6 cell lipo and its crazy  weelies this all i can write  and 57mph of fun  very nice settup but (i think to powerful for beginner on 6 cell)
mamba monsterv1 90f(30min)motor 120f and the lipo are 97f
10.23.2008, 12:45 PM
very good write up, i was running my castle 1y on 5s in a truggy, pure insanity. quickly found out that my wheels werent balanced well... :D
10.23.2008, 12:52 PM
That's exactly my next task.. Wheel balancing.
