Originally Posted by BrianG
I'd imagine you'd run 2s on the BEC side and 3s on the non BEC side...
That would be the best way. However, you can run a single 4S or 5S pack but you have to use an external bec and arming the esc is tricky as you have to power up the receiver then turn the esc on and then back off.
I was also told that 5S on the HVPro runs very hot. I only have a single 5S pack so I decided to just run 2x2S packs to be safe. I ran the HV Pro last Sat and it was pretty solid, runs hot, but a solid system. It doesn't seem to have as much torque as my mmm/neu though.
