I picked up the FLM tranny for my Slash specifically because I wanted a more solid mounting surface for the motor and the case acts like a heatsink (ok, the nice shiny aluminum had something to do with it too
). Well, I have some problems:
Problem 1: Hinge pins. Is there a better hinge pin to use? I got some brand new stock pins and they bind like crazy! Once I do get them out, much of the plating is scratched off the pin. I imagine these tiny flakes are causing the issue. I used a pipe cleaner to clean out the hinge pin holes on the tranny, but it only helps as long as it takes me to insert the pin again. Again, these are brand new pins. I even checked them for any surface irregularities before I installed them and they were fine. I pull them out and they are noticeably scratched/scuffed. This is happening just during
installation, I'd hate to see what happens after it's been running for a while - I'd probably have to cut them out!
If I can't find a decent pin replacement, I'm gonna hack off the hinge parts from the stock plastic tranny and put those on there instead.
Problem 2: RPM arms. I got some RPM arms and they do not fit. I had to dremel out about 1mm total from the inside of the arms where the hinge pins are. This really isn't an FLM issue as the stock arms fit fine. And the RPM arms fit the stock tranny. Go figure. The modded arms are ok, but am thinking about going back to stock. If I need to replace something in the field, I probably won't have my dremel with me.
Problem 3: Play in the input shaft. After installing the gears according to the Trx blow-up diagram (including the proper size shims), there is about 0.5mm of play on the input shaft (spur gear shaft). I had to disassemble it and add one more shim. Now it's good but I did not enjoy taking everything apart for just one shim. Grr.
Basically, I am stuck at the hinge pin issue. So if anyone has some answers for that, I'd be grateful.
On this Slash, I went from stock on 7 cells, to the MM/5700 on 10 cells, and now to a Medusa 50/2200 on 4s. I'm beginning to think I should just bring it back to stock.
