What’s the best LiPo 3s hard case?
E-Maxx Sweden
What’s the best LiPo 3s hard case? - 12.10.2008, 12:04 PM
Hello
What’s the best LiPo 3s hard case that money can buy, I like to have the very best you know
I will run those with my Mamba Monster + 2200kv com and FLM Chassi and
UE 6 spider diffs.
Best Regards
E-Maxx Sweden
skellyo
skellyo's Avatar
12.10.2008, 01:45 PM
The only 3S hard case Lipo that I think is up to the task of running a MMM combo is the Trakpower 3S 4900 packs.
E-Maxx Sweden
12.10.2008, 01:47 PM
Hmm the trakpower 3s 4900 mah is just Continuous Discharge Rate: 16C, 86.4A (not 100A or more) ????
I'll guess I won't get a better one (hmm would like these one, not in stock, Thunder Power TP5000-3SPR 5000mAh 3-Cell/3S 11.1V 40C 80C 200A)
Regards
E-Maxx Sweden
Erevocanuck
12.10.2008, 07:31 PM
Thunder power is come out with alot of different hard case lipo in 2009.one is a 3s 8000 mah hard case pack
Horizon hobby page
skellyo
skellyo's Avatar
12.10.2008, 08:26 PM
No, the Trakpower 4900 is 25C continuous. The 5400 is 16C.
12.10.2008, 08:50 PM
for less money you could buy a zippy 6s 5000mah 20c
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
2 of those in parallel is 6s 10,000mah 40c! for $270
http://www3.towerhobbies.com/cgi-bin...?&I=LXUYY3&P=7
two of the hardcase in series is 6s 4900mah 25c for $340
the math speaks for itself.........
skellyo
skellyo's Avatar
12.10.2008, 09:01 PM
Not really...
The Zippy packs are not hard cased like he asked for. Also, the combined weight of 2 of those zippy packs is 3.4lbs while the pair of Trakpower 3S 4900's is 1.8lbs. That's a huge difference!
I do agree, there are many cheaper options...but not in a hard case.
12.11.2008, 04:58 PM
Originally Posted by skellyo View Post
Not really...
good points. I've been back and forth about your hardcase lipos, and for the same money I can get more power. But they look so coool.......
dirt101
dirt101's Avatar
12.10.2008, 09:04 PM
and anyways you should know at 892 post that when you run a pack in paralel you dont double your c rating just your mah.
rustler, lx2e, xxt cr
ICUBoy
12.10.2008, 09:33 PM
I thought you DID double the C rating- surely each pack now can source the original C rating, and now there are two? MAh will be doubled, and voltage will stay the same? Maybe I need more sleep but the total power the packs can deliver will double (whereas in series the voltage doubles but the mAh and C rating is the same given the same load and no voltage sag).
dirt101
dirt101's Avatar
12.10.2008, 09:37 PM
no the current will double from the extra mah.
5000mah at 10c gives 50amps
10000mah at 10c gives 100amps.
12.11.2008, 04:55 PM
ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh. Thank you. That makes sense. I knew it could handle twice the amp load, but the c rating would have to stay the same or it would quadruple! you schooled me!
skellyo
skellyo's Avatar
12.11.2008, 08:15 PM
Those will work well for you. The 2S Trakpower 4900's I had were excellent packs.
E-Maxx Sweden
12.11.2008, 08:35 PM
Thanks skellyo, great to hear, I'll guess it arrives in next week I let you know my findings (if it's not snow or rain on the surface).
Best Regards
E-maxx Sweden
PS you can follow my build thread here: http://monster.traxxas.com/showthread.php?t=444391
