rear wheel guards and carbon fiber shock tower ???
CRTIM
rear wheel guards and carbon fiber shock tower ??? - 12.12.2008, 12:16 AM
Just curious what the purpose is of having the rear wheel guards i see on some of the truggies and buggies
like these for instance??....http://www.amainhobbies.com/product_info.p...oducts_id/13897
also...what are the pro's and con's on using the carbon fiber front and rear shock towers??,like this...
http://www.amainhobbies.com/product_info.p...roducts_id/8701
i'd like to cut some weight on my crt x2....but are they strong enough also ?....thanks for the advise
Semi Pro
Semi Pro's Avatar
12.12.2008, 02:12 AM
pro's of carbon fiber are that its lighter than aluminum,cheeper than aluminum the cons are that they can be broken easyer
the rear mud guards protect the cvd's from mud and rocks
MetalMan
MetalMan's Avatar
12.12.2008, 03:53 AM
I don't know about CF being cheaper than aluminum. Low quality CF maybe, but the good stuff typically costs a lot more. For the same thickness CF will be more rigid than aluminum, but under enough stress will fracture. Under the same loading aluminum would bend.
Semi Pro
Semi Pro's Avatar
12.12.2008, 04:46 AM
well i was refering to the cost of parts made out of them
i can get 3 carbon fiber shock towers for what 1 Fioroni shock tower cost
MetalMan
MetalMan's Avatar
12.12.2008, 04:50 AM
In that case, imagine how much a Fioroni CF shock tower would cost!
MustGoFaster
MustGoFaster's Avatar
12.12.2008, 12:10 PM
Rear wheel guards are very easy to make using lexan (use left over from one of the bodies you have cut out).
Semi Pro
Semi Pro's Avatar
12.12.2008, 02:30 PM
CRTIM
12.13.2008, 12:16 AM
Thanks guys
rootar
rootar's Avatar
12.13.2008, 01:55 AM
i would suggest making your own mud guards, i made these for my rc8t in about 20 mintues (that includes drilling 2 tiny holes in each arm) you can find good thick clear plastic from just about any kinda packages. then just throw a sticker on there and youve got some cool mudguards. they really help alot for keep the rear axles clean....
CRTIM
12.13.2008, 02:54 PM
very cool ,i'm gonna give that a try ....thanks
