Firmware upgrade bricked my mamba?
e-mikey
Firmware upgrade bricked my mamba? - 12.14.2008, 02:25 PM
I finally got around to setting up my brand new mamba max. I plugged it in, it prompted me for a firmware update. As soon as I did it, the ESC would not arm. I set auto lipo and I hear the 2 beeps (2s), but after that , the red light just stays on, it never gives the arming confirmation tone.
So what I do is drop it down a few version. Now it arms but it wont move. As soon as I give it throttle, I get a high pitch squeal . I can even see the red/white/black wires move, but the car wont budge. I see the pinion "tweak" a little, but thats it.
Is this a common issue when people update their mamba max (not monster?) Is there anything I can do?
auto2
12.14.2008, 02:40 PM
did u reset the radio end points after the upgrade? it may just be waiting for that.
bdebde
That's All Folks!
bdebde's Avatar
12.14.2008, 02:43 PM
^+1 on reset to radio^
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.14.2008, 03:26 PM
check your motor wires! I have had one pesky wire that doesn't like to stay soldered into the bullet and when it comes apart it makes a horrible squealling sound and stops moving.
pullinteef
pullinteef's Avatar
12.14.2008, 06:30 PM
I've seen what you describe (motor wires moving and motor shaft vibrate) when the ESC was set to brushed mode and connected to a brushless motor. As soon as I switched it back to brushless mode it was fine.
e-mikey
12.21.2008, 02:18 PM
E-revo that's the first thing I checked, it was a long soldering learning curve for me and it does seem like it's a bad solder.
What is resetting the radio endpoints? I am using a spektrum 3.0. Are you talking about re synching?
I will check the brushed vs. brushless settings..
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.21.2008, 02:24 PM
make sure your endpoints are set to 100% not higher. but I don't think the endpoints would be the problem. Re syncing the radio and esc might help but doubt that too. Re-binding won't do anything, your obviously getting the signal through. If it's not the brushed/brushless mode and all solder joints are good I would try another motor if you have one or at least make sure your motor spins by hand.
e-mikey
12.21.2008, 02:26 PM
another thing to mention is that the wires get very hot when trying to give it throttle.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.21.2008, 02:31 PM
It may be a bad motor (locked/shattered rotor) how long are the screws holding your motor, they maybe shorting out the windings inside.
e-mikey
It was set to "brushed reversing"
Stupid me.
Thanks!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.21.2008, 02:33 PM
Ahhhhhh!!! brushed mode only sends power to the red and black wires, nothing to the white. Essentially acting like a bad solder joint or disconnected wire!
pullinteef
pullinteef's Avatar
12.21.2008, 03:37 PM
Ha! What do I win?? :)
Andrew32
12.21.2008, 06:37 PM
the respect of all who have learned from your wise speaking
pullinteef
pullinteef's Avatar
12.21.2008, 10:28 PM
How much can I sell that for on eBay?
Andrew32
12.21.2008, 11:09 PM
well in the olden days you could probably buy a kick in the balls...not with the economy down itll probably only come out to maybe a slap in the face
