CRT.5 as my next basher?
PedeBasher
PedeBasher's Avatar
CRT.5 as my next basher? - 01.25.2009, 07:56 PM
Hi guys, I am new here but I have been watching for a long time. Im no noob either.
I have a couple questions for you guys regarding CRT.5s.
My birthday is coming up and I want something to replace my Pede. It was a great truck but its days are numbered for now.
I was thinking something along the lines of a CRT.5. Its nearly the size of a Pede, 4wd and it should be cheap to convert once I get everything out of the Pede.
I am mainly a basher though. I do run on tracks now and again and my track (Leisure Hours) has occasional CRT.5 mains. I think it would be fun to race against some nitros but still have a great bashing truck.
So my question to anyone who has converted one is... Is it a good basher? I am by no means easy on my trucks. I can be if I have to but I like the "Go Big or Go Home" aspect of R/Cs.
I was also planning on running my Sidewinder 5700 and TrueRC 2s 5000mAh lipo and gear accordingly. Would that be enough? Can I pull it off without having to drop $135 on a Mamba Max ESC? I only really need like 35mph, enough to hit a ramp and go high LOL.
If not, what else do you guys think would be a good replacement? Im not too interested in another Pede or Rusty, Slash, Bandit. Id like something 1/10th scale and 4wd if possible.
And for all you guys saying that I should go 1/8th, Ive already got a 1/8th project.
Sorry for the long rant. I wanted to be precise so you guys have a feel for what I am looking for.
- Ben
  Send a message via AIM to PedeBasher
01.25.2009, 08:02 PM
Well, the CRT.5 is a good basher. Pretty strong and built like an 1/8 scale vehicle. However, I would not use the 5700, it will just heat up when geared at anything over ~25 mph, especially in the heat of summer. You can still use the sidewinder ESC, but run 3s on a 3300-3500 kv motor. The Medusa 36-50-3300 works well in my CRT.5 and is much stronger and stays cooler despite being the same physical size externally. And running 3s on a lower kv motor is more efficient than any 2s setup, and the SW will handle it fine.
Some will say to get Mike's extended kit. It makes it closer to 1/10 scale, but don't know if that's in your budget. If you do go this route, I would get the 36-60-3100 and still run it on 3s.
PedeBasher
PedeBasher's Avatar
01.25.2009, 08:35 PM
Huh. 3s might be a problem. Could I pull off 2s with a lower KV motor? I spose I could get a 3s lipo but I have a couple 2s lipos and it would be easier for me to run those.
Well, now that I think about it, Easter and my birthday are like 13-14 days away. Maybe I could work on getting a 3s lipo.
Its great that they are tough though. Thats exactly what I'm looking for. I know CRT.5s can handle pretty well too.
Do you know of any cheap lower KV motors what would work well? Maybe an Ammo? Ammos from what I hear are pretty decent and are good performers for the price.
Thanks for your help.
Did you know?
01.25.2009, 08:47 PM
You get what you pay for w/motors, so....if you have to , my suggestion would be to save for a GOOD motor....(as Brian stated above, a 3300kv 50 series Medusa on 2s is a good choice..) so you don't have to buy another one after your inexpensive one blows up in short order. I have 2 crt.5 and love them...one is my daughter's which is in my sig...the other I am redoing and it will have a super stretch chassis... and I am running that one on 3s w/a 1509 Neu motor.
Mike's extended chassis kit is well worth it IMO...Best of luck w/your choices!
Also, welcome the the forums!
PedeBasher
PedeBasher's Avatar
01.25.2009, 09:25 PM
Thanks! I think I will like it here!
I think I might be selling my E-Maxx soon so a nice Medusa might not be out of the question.
As for the chassis, well time will tell. I wont be suprised at all if I end up with one but for now a CRT is just a dream.
I really hope I can pick one up. As long as this economy doesnt get worse or something bad happens, one is in my future.
Thanks for the help guys and keep it coming! I want to know the most I can about this bad little rig!
Did you know?
01.26.2009, 01:02 AM
...(as Brian stated above, a 3300kv 50 series Medusa on 2s is a good choice..)...
Actually, I would run 3s. 2s will require a decent amount of current to get the speed you want. And not only is high current less efficient, the sidewinder might heat up a bit. My full MM ESC heated up quite a bit running the 4600 on 2s, and that was geared 46/12. Needless to say top speed was crappy. I can't imagine the Sidewinder will fare any better heat-wise on 2s. And using normal 2.2" tires is effectively like gearing up a tooth or two, so that just makes things worse.
Yeah, you can gear up the 3300 to compensate, but the required current of a low kv motor geared high will be just as high as a higher kv motor geared down to get the same speed. So you don't really gain anything. 2s can work, but I would definitely go 3s. Believe me, I didn't relish the idea of buying new 3s lipos either, but I'm glad I did. Now, my setup is not nearly as finniky with gearing.
I think you'll be happier overall with 3s. And any comparable 4wd vehicle will benefit from 3s, so this doesn't apply just to the CRT.5.
PedeBasher
PedeBasher's Avatar
01.26.2009, 03:13 PM
I will find a 3s somewhere. Maybe a Zippy. Cheap but amazing.
Thanks for your help Brian! Any other info anyone has would greatly be appreciated!
Did you know?
01.26.2009, 06:12 PM
My misprint Brian....I meant to say 3s not 2s.. Thanks for the clarification!
01.25.2009, 08:38 PM
I will have a converted CRT.5 to sell in a couple of weeks time if you are interested...
emaxx101
emaxx101's Avatar
01.25.2009, 10:29 PM
I recently bought a crt.5 and im runnin a VXL on 3s and its the most fun. I cant tell you if its a good basher or not because i havnt built a battery box strong enough to keep the battery in the truck.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
01.26.2009, 12:45 AM
+1 on 3s & a medusa 36-50-3300. Its a fantastic combo.
If you want to stay on 2s, I have a lehner basic xl 4200 that I could sell you. I was running it in my crt.5 on 2s and regularly getting 35mph with good temps on 16/46 gearing.
rcm xt8
rcm xb8
rcm crt.5
bensf
01.26.2009, 12:54 AM
I've broken a lot on mine. But I also have it geared for 70. . .
01.26.2009, 03:28 PM
Just to conflict :) - I run 2s and gear up with the Medusa 50 3300 and it has no issues - lots of fun.
I have the enerland 25c hardcase lipos though...
I also have some ma 3s lipos or dual stack to 4s if i want to have crazy speed.
01.26.2009, 04:12 PM
Just to conflict :) - I run 2s and gear up with the Medusa 50 3300 and it has no issues - lots of fun...
I think you just like to conflict for the sake of conflicting. Every forum has one (or two).
Seriously, it depends on the quality of the battery. A 2s setup can be done if using really good cells that can deliver the current while maintaining decent voltage. To be fair, I was using MA 5Ah 2s packs, and know that was some of my problem.
