Discharging lipos
jnev
jnev's Avatar
Discharging lipos - 02.16.2009, 10:24 PM
Having never discharged a lipo before, how do you determine the amperage to discharge it at? I have always just ran the packs down, and then recharged to the storing voltage, but never discharged... any other settings I should change for discharging?
Thanks in advance.
02.16.2009, 10:38 PM
As a rule of thumb, I discharge at 1/4 the amperage I charged with, presuming I charge at 1C.
02.16.2009, 11:00 PM
Why would you discharge a lipo? You can store them with any charge...
02.17.2009, 01:41 AM
Why so low? I mean you discharge them in your vehicle at way higher than 1C. Just curious.
Anyway, I usually just discharge them by running them in my vehicle, then charge them up to half the capacity. So, if they are 5Ah packs, I put 2.5Ah back into them. If this is not feasible, then I just discharge them via a resistor load until they get to ~3.7v/cell under load. Once I remove the load, they usually rebound back up to ~3.8v/cell. Of course, I have to watch this process, but I'm usually at my bench anyway...
Confused.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Confused. - 02.17.2009, 02:25 AM
SInce it is inherently damgerous to allow Lipos to go below 3.7V why would you need to discharge them anyway. I would think storing them at full capacity would be a better method so they will not fall below the required 3.7v level whether you store them for one month or 12 months. As long as you store them in a good fireproof container you should be good to go.
SUPERMAXX YOUR LIFE.
02.17.2009, 02:47 AM
3v per cell, not 3.7v Jerry.....
Yea yea yea.
JERRY2KONE
JERRY2KONE's Avatar
Yea yea yea. - 02.17.2009, 05:14 AM
Yea I know James. That is what I meant. I am just saying why discharge Lipo's at all for storage? Especially if you do not know for sure when you might use them again. Just charge them up, and lock them away.
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
02.16.2009, 10:59 PM
if you have storge mode in your charger you dont have to discharge anymore
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
jnev
jnev's Avatar
02.16.2009, 11:51 PM
This is actually for a neighbor, who has been on and off into rc. He hasn't ran the packs in about a month and a half, and has just been repeaking them and balancing them every two weeks or so. I think it would be better to just keep them at storing voltage, and recharge them when he runs them again. What do you guys think? Or just keep going with the same routine he's been doing? The charger also does not have storage mode unfortunately (Superbrain 989). Thanks BL_RVO. I'll try it out I think once I hear other's opinions on whether I should discharge the batteries or not.
02.17.2009, 10:45 AM
According to many places, keeping lipos at an elevated voltage encourages corrosion inside the cell. Discharging to around 3.7-3.8v reduces this. Lipos have VERY low self-discharge, so they'll be fine at that level for months.
Good stuff.
JERRY2KONE
JERRY2KONE's Avatar
Good stuff. - 02.17.2009, 10:49 AM
Its good to hear from the people in the know. Thanks for the info BG.
hoober
02.17.2009, 01:46 PM
discharge any battery at any rate up to the max of the specific battery. Users choice.
Most of the time the discharge device will be maxxed out long before the battery is. It might be safe to use the continuos current rating divided by 2 if the pack is healthy. At times it may be ok to use the rating itself if the pack is accurately rated. If it's a used/bad/worn pack then the continuos rating divided by 5 may even be the max.
