04.03.2009, 06:32 PM
First, welcome.
I have 2 set up differently..one is my daughter's ( the 1st. one listed in my sig.) Mine on 3s flies ...so you need to figure out how fast you want to go
1. What size is the motor...3500kv?
2. how many cells are you plan on using?
3. A lot of people like bow-tie tires
4. If you run 3s you should use a bec of some sort
5. regardless of your set up...I'd start w/a 14 or 15t pinion and go from there and adjust according to desired speed and for temps.
