More Speed Reverse? Less Speed Forward? -
04.10.2009, 04:38 PM
ok i just did a test run with my E-Revo and i have more top speed in reverse than forward any setting u guys would recomand for faster forward speed than reverse? running MMV3 w/ Wander 10xl gearing is 17/62 not really use to the USB set up reading the manual to under stand it more
You need to swap the servo resverse on your radio for the throttle channel, recalibrate the radio, and most likely swap 2 of the motor to esc wires. Take the pinion off and see if the red or green light on the esc comes on when you throttle forward. If the red comes on you need to swap the servo reversing switch and recalibrate so that the green light comes on when you throttle forwards. Then put the pinion back on and see which way the truck goes, if it goes backwards when you throttle forwards you need to swap 2 of the motor wires.
I also ran into this before...a little confusing to sort out at first
If you have the Futaba radio, you need to reverse the throttle switch. If not, just swap 2 of the wires.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
