MMM with DX6i
MMM with DX6i
KaztheMinotaur
MMM with DX6i -
05.11.2009, 06:55 AM
Has anyone successfully calibrated a MMM to a Spektrum DX6i?
Does anyone know if the steering channel on a SR3000, bound to a DX6i, would be operated by left and right movement on the right stick?
KaztheMinotaur
Find all posts by KaztheMinotaur
2
05.11.2009, 08:03 AM
I run my MM with a DX6 so don't think it will cause any issue - I would think you need an air RX - I use an AR6000 IIRC
Find all posts by Arct1k
3
KaztheMinotaur
05.11.2009, 08:57 AM
Do you have it set up to run the steering with left - right on the right stick?
KaztheMinotaur
4
05.11.2009, 09:11 AM
I'm using it on a crawler:
left stick
---left/right steering (front)
---fwd /back for dig
Right stick
---left/right steering (rear)
---fwd /back for throttle
Mixing is setup for linked front (master) and rear steering with opposite travel and delinked for independent movement...
5
KaztheMinotaur
05.11.2009, 09:16 AM
Did you find it hard to switch to a stick radio to run teh crawler?
Do you run your other surface RCs with the DX6?
KaztheMinotaur
6
05.11.2009, 09:18 AM
Only the Super crawler - Still finding it a little hard to get used to.
I almost gave up on it but need the 4th channel for steering.
Only other option is to buy the punk computer...
7
KaztheMinotaur
05.11.2009, 09:20 AM
Is the RX you are using?
KaztheMinotaur
8
05.11.2009, 09:42 AM
Thats DSM2 i'm using a 6 so DSM1 AR6000
Hybrid Mode
Switch to Threaded Mode
Off
