motor/kv/ system question
mk351e
RC-Monster just don't get it
mk351e's Avatar
motor/kv/ system question - 05.12.2009, 12:31 AM
imagine the following 2 scenarios, the goal of both is to move a 12 pound monster truck at the ridiculous rate of 55mph or so, both systems at 6S, and BOTH SYSTEMS HAVE THE MOTOR SPINNING THE SAME SPEED, AND SAME VEHICLE SPEED:
1) 2200kv motor with a whatever-size-you-want pinion, but throttle epa turned way down, truck goes 55mph
2) lower than 2200kv (1700kv??) motor, same size pinion, epa @ 100%, truck goes 55mph
the question - regardless of what you may think about running a monster truck at these speeds, are there any differences between these 2 setups? In other words, is the motor, battery, or esc working harder in either system? My guess is that the motor in both setups should run the same temp, but I'm lost from there.
HELP!
05.12.2009, 01:12 AM
why?
05.12.2009, 10:35 AM
why?
you simply wouldn't want to run a brushless setup with your epa turned down. As stated before it's rough on the esc and causes heat. You wouldn't buy a corvette and unplug 2 spark plugs, it just doesn't make sense.
05.12.2009, 10:47 AM
Yeah, they barely run as it is!
littlegiant
05.12.2009, 11:10 PM
Is the EPA setting relative to the kv rating of the motor?
case 1: A 4000 kv motor at 4S EPA 100%. Motor has max efficiency at 40k rpm. The rotor will be turning at 59.2K rpm which obviously is going to heat up the motor and possibly over work the esc.
case 2: The same motor at 4S at EPA 67.5%. Assume that the motor is running at 40K rpm which is at the max efficiency rpm. Motor will be running cooler and not overloading the esc.
Will the above be true?
05.12.2009, 11:35 PM
its just a silly backwards way of doing things. you first figure out what batteries you will run, then match your motor kv to that. If you're overvolted get a smaller battery, don't turn your epa down to compensate.
littlegiant
05.13.2009, 12:24 AM
Now that u mentioned it, will it work well by compensating with EPA values down?
Will it cause any damage to the system? Will the esc work harder with a lowered EPA setting to meet a specific range of motor rpm? I mean as compared to the same rpm range of a system with 100 EPA but with lower cell count. If the motor to be used is identical in both setups.
I was thinking that as long as the motor is being operated at its recommended range of RPM for good efficiency, the cell count or epa value doesn't matter. Please correct me on this. Thanks.
Any explaination as to y it is not recommended to compensate by reducing EPA values other than that the esc could be working harder?
05.12.2009, 06:05 AM
Option 2 - more effecient lower temps...
Motors have an effeciency curve IIRC using EPA is not ideal...
littlegiant
05.12.2009, 07:39 AM
Yes option 2 will have lower temps but i don't think that it will be lower by much. Probably by 1 C??? The kv difference isn't all that much.
05.12.2009, 07:59 AM
eh thats like a 1y vs a 2.5d... Amost 33% more KV's in the 1Y... ie 37.7k RPM vs 48.8K RPM
Quite a difference...
littlegiant
05.12.2009, 08:28 AM
Well then any idea about the temp diff for that 33% kv diff?
05.12.2009, 08:38 AM
Well I have both motors, 6s batteries, an eagletree and a temp gun
hmmm only one problem - my pinion is set screw is stripped on the 2.5D on the the revo...
When I get a spare day I'll let you know...
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.12.2009, 10:22 AM
Speed controls aren't as efficient at less than full throttle. ESC would have more heat with throttle end point turned down. A 1515 2.5d on 6s will get you to 55mph easily as long as you have a smooth finger, otherwise you'll wind up on your lid, same with a 2200kv motor.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.12.2009, 11:50 PM
Here's an idea: 2200kV motor at 100% EPA going 70mph.
Other than that I'd use the second option. Compensating with EPA seems a bit backward to me also.
mk351e
mk351e's Avatar
05.13.2009, 12:05 AM
well, the question has been asked "why", and it's real simple; see my other thread!!
