I have destroyed my on/off switch an wondering how to replace it. Is ther any place where i can bye a new one? Does it have to be a original or can i use something else. Sorry for my bad english,i`m from Norway hehe..
You can use something else, but there is also the program switch on there as well. Before it even became a problem, I replaced mine with a couple of switches (toggle for the on/off, and a momentary for the program) and mounted them in a mini servo case:
I think I have the wiring diagram somewhere at home. I'll take a look when I get home so you get the wiring right.
OK, I can't seem to find the diagram and I really don't want to take the switch case apart. If someone can remove the black casing from the switch assembly and post a clear pic of both sides, I can tell you which is which. I do know that there is common wire and I *think* that is the red one (middle).
