Pinion Gear... Whats up?
Mentat
Brushless Mentat
Mentat's Avatar
Pinion Gear... Whats up? - 07.15.2009, 02:51 AM
After running this 15t pinion gear for the last month or so with a 48t metal Spur gear, i noticed today that it started making a funny noise. after closer inspection i found this. Did I have the meshing to tight? Or did it just wear out? I ran it alot over the last month and always on the track. Thoughts, Ideals? Stock Losi Electric Conversion Pinion.
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
OZ-RUSTLER
OZ-RUSTLER's Avatar
07.15.2009, 03:06 AM
What brand pinion is that? Is it Hot Racing?
Mentat
Brushless Mentat
Mentat's Avatar
07.15.2009, 03:14 AM
As stated above its a stock losi pinion it came in the Losi Electric Conversion Kit 15T
OZ-RUSTLER
OZ-RUSTLER's Avatar
07.15.2009, 03:18 AM
I dont think that pinion is hardened.
Mentat
Brushless Mentat
Mentat's Avatar
07.15.2009, 03:27 AM
Yeah i dont think it is either, is it normal for a pinion to wear like that against a metal spur gear?
OZ-RUSTLER
OZ-RUSTLER's Avatar
07.15.2009, 04:03 AM
I wouldn't think so, after just a month.
How many packs have you run in a month?
Mentat
Brushless Mentat
Mentat's Avatar
07.15.2009, 04:13 AM
a good 15 or so
07.15.2009, 06:48 AM
Yes if it isn't hardened well - Get an RCM pinion = problem solved
Dafni
Dafni's Avatar
07.15.2009, 06:51 AM
Yep, it does look like it was not (properly) hardened. Just get a pinion from RC-Monster and you'll be fine.
Finnster
KillaHurtz
Finnster's Avatar
07.15.2009, 09:53 AM
Yeps, buy cheap, buy twice. I have RCM pinions a few years old and have little wear. Don't bother w/ Losi, HPI, novak, etc.
brushlessboy16
brushlessboy16's Avatar
07.15.2009, 08:05 AM
Have seen many of thse, as stated-it comes from a poorly or un-hardened gear
like this:
nitrostarter
nitrostarter's Avatar
07.15.2009, 10:35 AM
Maybe because those pinions are made to work with the Plastic 45T spur gear that comes with the kit.
N. Rustler conversion
07.15.2009, 11:10 AM
Bingo...
As stated a rcm pinion will be your best bet. I had a talk with Mike a few weeks ago and he gave me the inside scoop on his pinions, and why they are superior. The metal that they are made of is better than any of the the other pinions, including rrp. Also consider that if you are running a 15t pinion with a 48t spur you have around 3:1 ratio, so you will have 3 times the wear on the pinion teeth vs the spur teeth. That is why the pinions wear out. Your mesh may have been a bit tight, I usually set the mesh by sound, if it is very noisy 10 to 1 it is a bit tight.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.15.2009, 12:08 PM
RCM pinions are awesome!, works like a charm..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
07.15.2009, 12:19 PM
I third that. RCM pinions are the best. RRP are also good, but support the monster! Novak pinions are also OK, they do hold up, but for the price just get a RCM pinion.
