Losi Smart Diff and plastic spur compatibility
nl12
Losi Smart Diff and plastic spur compatibility -
07.24.2009, 10:17 PM
Does the Losi Smart Diff and the losi plastic spur conversion work together?
nl12
Find all posts by nl12
2
GO-RIDE.com
07.25.2009, 12:45 AM
It should the SD works fine with the Kyosho plastic spur.
E-CRT.5 Monster
- RCM chassis, MM/Medusa 50x3300/3s, truck tires, 1/8 shocks
E-CRT.5 Stock
- Sidewinder/4600/2s, buggy tires
E-8ight
- Tekin RX8 2000kv/4S
E-8ight T
- Tekin RX8 1700kv/5S
GO-RIDE.com
Visit GO-RIDE.com's homepage!
Find all posts by GO-RIDE.com
3
nl12
07.25.2009, 08:49 AM
does the kyosho fit without dremeling? Is it a better choice than the Losi gear?
nl12
4
GO-RIDE.com
07.25.2009, 12:24 PM
It's a tight fit, but snaps into place as you tighten down the screws. From what I've read the Kyo spur is more durable than the Losi. If you do go with the Kyo spur then also pic up the Kyo outdrive o-rings.
E-CRT.5 Monster
E-CRT.5 Stock
E-8ight
E-8ight T
GO-RIDE.com
Hybrid Mode
Switch to Threaded Mode
