Go Back   RC-Monster Forums > Support Forums > Team Tekin
Gearing help
Brushless Moose
Gearing help - 09.19.2009, 03:03 AM
What pinion should I run with the tekin RX8 and 2050kv buggy motor? I am running a 48t spur on a losi 8ight,running 4s. Right now I am running a 16t pinion and the motor is getting waay to hot (185F). Am I under or over geared?
What pinoin should I run? I cant change Motor timing because I don't have the hotwire.
TekinTeamMgr
TekinTeamMgr's Avatar
09.19.2009, 04:06 PM
You're a bit tall for a 2050. Try the 15.
  Send a message via Yahoo to TekinTeamMgr
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.19.2009, 04:19 PM
Use this to calculate your max top speed and will help determin proper gearing.
http://www.scriptasylum.com/rc_speed/index.html
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.19.2009, 05:15 PM
Well it probably is the timing that is the problem, but try lower gearing first. Even a 14 tooth w/ the 1900 is still as fast as the nitros and a 2050 will be even faster. A note on timing... Using 0 timing with my 1900, I can use ANY size pinion gear up to a 20t in my 8ight and temps will always be less than 140 at the end of the run on 4s lipo.
Area 52 Ranch Raceway
T.R.C.R.
Brushless Moose
09.19.2009, 09:56 PM
ran 4s 15t pinion for 7 mins with holes in body and 185F, Ran 17t pinion for 7 min and temp was 190F. Timing is zero
whitrzac
Can't catch this...
whitrzac's Avatar
09.19.2009, 10:14 PM
check for binding, and make sure the gear mesh is right...
Brushless Moose
09.19.2009, 10:59 PM
no binding, mesh is fine!
FG101C
09.20.2009, 02:09 AM
That motor is awesome in the Losi 8ight buggy, if you replace the buggy 40/13 ring and pinions with the truggy 43/10 gearing. The 40/13 just makes the gearing to tall, imo. This is from experience, on a TRACK in RACING conditions.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
09.20.2009, 09:39 AM
Driving style could be the issue. Are you sliding around in loose dirt, powering through grass, or never letting the throttle trigger breathe? And to make sure, you aren't running a big heavy monster 8000mah+ lipo are you?
Brushless Moose
09.20.2009, 01:44 PM
no, I am driving the buggy easy around a track. I am running 2 4s 3000mah 30c packs in parallel. I ran that with the MMM 2200 combo for 45 mins continuous with no problem, and now I cant run it with the tekin for 7 mins without overheating!
TekinTeamMgr
09.20.2009, 10:34 PM
Something sounds off here. 6000mah should not get your 45 minutes with either of these setups.
2200kv motor at best would see 20 minutes on a buggy I bet at least.
The temps say you're geared a bit tall. Do you have a hotwire?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.20.2009, 01:57 PM
What are you running in your center diff for fluid? I had been running straight 10k and temps where a touch higher than I liked, I changed the fluid and put a little bit of 50k in with the 10k and my temps are about 10* cooler. Although I didn't think I was unloading the front a lot apparentlly it was enough to raise the motor temps.
bdebde
That's All Folks!
bdebde's Avatar
09.20.2009, 02:36 PM
If the MMM combo worked fine, why switch?
Brushless Moose
09.20.2009, 06:13 PM
because the mmm burned up. I am running 15k in the center
Brushless Moose
09.20.2009, 11:01 PM
yep, I have a hotwire, and the 45 mins I speak of was running back to back. even doing that temps were under 150, but now with the tekin, I cant go 7 mins without it overheating!
