High-Voltage Fetish
Motor upgrades for flux? Also question on wheel wideners -
10.11.2009, 06:29 PM
Hey guys, I am not really up to date or informed on the "big" brushless motors. I am tossing around the idea of a motor swap in the flux, mainly because it's bothering me that it's stock haha. The performance is awesome, but it's still stock! Is there a motor I could swap in? I don't want "bang for the buck" I want the best of the best, I basically just want to know what is out there? If anyone "in the know" could give me some insight that would be great.
Also, I was thinking about a set of wheel wideners but I have heard they just break more parts?
extended chassis is on the way, so I figure I might as well give it some lovin' while it's apart and cold outside. Thanks,
-Matt
10.11.2009, 06:38 PM
Uh you really can't get much better then whats already in the Flux without spending ALOT more money. You could go with a novak sensored system to go with the next step I suppose
http://www.teamnovak.com/products/br...tem/index.html
No experience with wheel wideners though offset rims will give you extra control and stability.
Fat Kid Engineering
10.11.2009, 07:16 PM
Originally Posted by Freezebyte
Novak makes great products but it would be a turn in the opposite direction, The Flux is basically a Steve NEU designed Castle 2200kv motor with a different can/heat sink.
If your running 2s in series, a upgrade would be a Genuine NEU motor 1515 Y. I would suggest you spend you hard earned money on drive train upgrades and worry about another motor when you roast the one you have now.
High-Voltage Fetish
10.11.2009, 07:27 PM
I run it on 6s, and you may have a valid point. I more or less just wanted to know what my options were, for future reference. I have the diffs set up to where they seem to be holding, and just installed the HD drive gear. I'd still like a little more speed, maybe because I'm an idiot?
10.11.2009, 08:17 PM
Agreed the only possible upgrade might be a TRUE steve neu motor . But in my opinion most people could not tell the difference with out a eagle tree system .
High-Voltage Fetish
10.11.2009, 08:47 PM
From what I understand the biggest difference is durability?
10.11.2009, 09:40 PM
I would just leave it, but if you have too what about the new tekin rx8 seems like a nice combo.
10.14.2009, 12:03 AM
Feel free to put me on ignore if I'm such hassle, I could care less.
10.14.2009, 12:05 AM
I wasn't put on this earth to please anyone
So I have heard... Sorry dude, that was too easy!
KillaHurtz
10.14.2009, 12:24 AM
tut tut.. someone is being far too serious. We all do silly things at times (like draw a spider w/ only 7 legs.) Best just to have a laugh at it.
High-Voltage Fetish
10.11.2009, 07:03 PM
Hmm, might be tricky to find wheels I like with a decent offset.
Fat Kid Engineering
10.11.2009, 08:14 PM
When it comes time for a new NEU, get a lower KV version. It'll run cooler and speed will be more than you'll ever need prior to flight.
10.13.2009, 06:06 PM
On the wheel widening thing - i am not sure exactly what you are after - but i have run RD Logics 23mm Hub Extensions that worked very well - i ran them with Big Joes and Proline Cheyennes - i was quite worried at first, but they are strong as, and hold up very well - even with alot of bung/awkward landings and cartwheels, they have been bullet proof in my truck, but have not heard of anyone else running them funnily enough.
10.13.2009, 06:29 PM
Ok, the 2200 is a 1515 size neu clone.
So the logical upgrade would be a 1521 motor. If you get a smooth can it will bolt right into the stock flux mounts. Nothing else will fit (unless it is the same diameter as a smooth can 15 series neu). I run a 1521 1y (1577kv) on 6s in my large trucks, and it does very well. Since you currently run 6s and a 2200 motor you would need to re-gear quite a bit if going to a lower kv motor. Not sure if you can change the gearing enough to run a 1600kv motor.
As far as going to a Novak system???? Freezebyte, you must be joking, or you are a huge dumbass... 1st the setup you linked is for 10th scale, and novak does not sell anything close to the power the flux/tork setup produces (maybe run 2 of their "8th" scale hv systems?)...
Wheel wideners are not a good idea, extra stress on wheel bearings will just cause continual failures in that area. Get some high qual bearings and use a different offset wheel if you want it to be wider. Not sure but someone makes wider arms, cvds, etc for the savvy.
10.13.2009, 06:41 PM
FLM makes wider arms that work very well also =) I havent had any problems with my wheel extensions or in that area.... yet - but i've had well over 6 months of hard use out of em...
