Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
The best BEC on the market?
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
The best BEC on the market? - 10.19.2009, 03:43 AM
I just dont know what to buy anymore.... I race nitro truggys and use BEC's to regulate my voltage, BTW no I dont want to buy new servo's :)
I have tried novaks one and SMOKED it, im on my third CC BEC and absolutely hate them!! I have come to the conclusion that CC BEC is the absolute hugest POS out there on the market, from just turning the truck on or off ive smoked them... that is absolutely one product that I will never buy from CC again.
So in your guys exert opinion whats the best BEC out there?
rccna.com
10.19.2009, 04:06 AM
lipo is cool and all, but wouldn't a nimh 6v pack be much simpler than a lipo and bec? You make sure your rx pack is charged and ready anyway, right?
wallot
wallot's Avatar
10.19.2009, 04:09 AM
never had issues with dimension engineering BEC
however now I use RX8 internal BEC and low Amp draw BLS futaba servo :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
aqwut
Brushless Heavy Weight....
aqwut's Avatar
10.19.2009, 09:16 PM
Same here.. Mine is still working awesome!.. My castle BEC works great, I have 4 of them...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
its me
its me's Avatar
10.20.2009, 03:16 AM
thanks for the advice guys, we run 45 minute mains out here and if you do bump up then you would need to keep driving for the hour half.. Only the lipo packs can actually handle this kind of abuse with out needing a charge.. Oh and just to clarify I have now burnt my fourth CC bec..... ALL on different vehicles.. For me im done with CC becs..
rccna.com
emaxxnitro
emaxxnitro's Avatar
10.19.2009, 07:46 AM
you could try the cc bec pro... or use a nimh pack they all will work the same
808E
10.19.2009, 09:06 AM
koolflight makes a decent one as well
bdebde
That's All Folks!
bdebde's Avatar
10.19.2009, 09:52 AM
Dimension Engineering
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.19.2009, 11:44 AM
+1
There was a bad batch where one cap was installed in reversed, but that has been taken care off.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
its me
its me's Avatar
10.20.2009, 03:36 AM
What would you guys recommend? I was looking at the sport BEC?
rccna.com
bdebde
That's All Folks!
bdebde's Avatar
10.20.2009, 09:59 AM
Yep, that one is great.
10.19.2009, 10:59 AM
Any BEC currently on the market that I know of has the same basic circuit design. If the BEC fails, full battery voltage can be passed through it to the load. This is usually caused by an excessive voltage spike and/or high current loads. Since spikes are probably out of the question in this case, I would look at the servo being driven. I've had servos that appear normal on the bench have issues when running. In my case, one of the "axles" in the servo gear set had elongated an axle hole in the case. Under light load, it worked fine; under heavier running load, the added stress binded the gears. When that happens, it can pull a substantial amount of current.
George16
Supermaxx
George16's Avatar
10.20.2009, 05:31 AM
I have the Sport BEC and it works great.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
10.20.2009, 06:20 AM
Actually swap your servos to HV Hitec / JR and eliminate the bec...
maneba
10.20.2009, 02:45 PM
Why not use a Hyperion rx life instead of a BEC?
