So don't hit walls at WOT?
vader2728
E-Maxx Breaker
vader2728's Avatar
So don't hit walls at WOT? - 11.20.2009, 05:56 PM
Here's some pics of my most recent crash... Was about 50 yards away and runnin the E-maxx at WOT and out of nowhere comes this building... I had heard reports of a stray one roamin around in the park where we were bashin but I thought the noise of pinion mesh and Mamba Monster beeping all over would scare off any undesireables... Anybody ever have a Ti hingepin break into 5 pieces like this? Maybe I'm special after all! On to the pics... Meant to post this in the E-Maxx forum but it does have an FLM chassi in it... I guess it fits here too...
ID:	7996   Click image for larger version
ID:	7997   Click image for larger version
So that's what all the fuss was about...
Semi Pro
Semi Pro's Avatar
11.20.2009, 07:17 PM
this year i did crash my carbon fiber 8ight into the ground at about 40mph (Newton's Three Laws of Motion shouldnt apply to flying buggys) i bent a titanium hindge pin into a U shape, but i havent ever broken one into pieces
11.20.2009, 09:43 PM
the pictures are good proof but the logic seems flawed. Can anyone else verify that you should NOT run into buildings at WOT?
side note: I love the acronym WOT. I sometimes roll around making wide open throttle noises while saying "wot". WOT WwoTT WWWOOOOTTTTTTT WOTT WOTT WOTT WooooOOOOOOOOOOOOTTTTTTTTTTTTT (shift) WWOOTTTTT WWOOooootttttttTTTTT (shift) WWWWWOOOOOOOTTTTT
etc., etc.........................
vader2728
E-Maxx Breaker
vader2728's Avatar
11.20.2009, 09:51 PM
The GA bulks with a broken Tony's screw in it might be a lil more proof... Or the way I had to use the dremel to cut what was left of the hingepin out... The parts left in the bulkhead were both mushroomed out on the inside so i had to push them towards each other and cut the swollen ends off... Ha... I just used mushroomed and swollen in the same sentence... On a side note, Ti sparks are awesome!
JThiessen
JThiessen's Avatar
11.20.2009, 10:05 PM
You probably didn't know that ahead of time.....grinding Ti is not a good idea...
11.20.2009, 10:07 PM
I have run into stationary objects w/my buggy at WOT several times...never w/good results
Kcaz25
Kcaz25's Avatar
11.20.2009, 10:08 PM
Gnarly! GA bulks are tough!
vader2728
E-Maxx Breaker
vader2728's Avatar
11.20.2009, 10:23 PM
Not good? Oopsie! Is cutting considered the same as grinding? O well, if the smoke from the casino I work in don't kill me I can blame it on Ti dust!
vader2728
E-Maxx Breaker
vader2728's Avatar
11.20.2009, 10:29 PM
@ kcaz25... 7075 bulks with Strobe braces, k'heads, UE EXT 15mm suspension, Ti skids (that I havent cut or grinded), Gen IV saver and Ti steerin links is pretty tough! I guess the Maximizer beadlock, the hingepin and the broken screw were a pretty good tradeoff for what coulda broke !
Kcaz25
Kcaz25's Avatar
11.20.2009, 11:55 PM
No doubt, I think I've seen your truck on UE.
vader2728
E-Maxx Breaker
vader2728's Avatar
11.21.2009, 12:04 AM
I cant remember if I ever posted the finished product or not... I've been busy breakin, er playin with it ... The E-Maxx too...
JThiessen
JThiessen's Avatar
11.20.2009, 10:41 PM
Cutting is different. On second thought, with the size of the hinge pin and speeds the dremel is only capable of, there really isn't much danger, just a lot of white sparks.
Issues come up when people use the same grinder for different materials - especially aluminum. Aluminum will embed in the grinding wheel, and once it heats up, can cause the wheel to explode.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
11.20.2009, 10:55 PM
I'm a welder and I have never heard that before in my life. I've used a disk covered in alum. to grind steel lots of time, no blown up disks. Unless you have personally seen it happen, I think whoever told you that is full of shit lol.
On that note though...wierder things have happened, pure oxygen and oil has been known to explode.
11.20.2009, 11:03 PM
I spontaneously combusted once...
11.20.2009, 11:09 PM
Originally Posted by Slowkrawl View Post
I'm a welder
I also weld and weird things have happened to me as well. Pure Oxygen and petroleum products don't always mix..
