Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
MMM/2650 + Slash 4x4 = FIRE!!
kazuaki
Unhappy MMM/2650 + Slash 4x4 = FIRE!! - 01.06.2010, 09:18 PM
I have been patiently waiting for the new Slash 4x4 to be released. When I heard about the Platinum Edition, I cancelled my preorder of the RTR and ordered the PE instead. I finally go the truck on Monday. Traxxas set the truck up to accept the MMM combo, so I installed a brand new MMM/2650kv combo from the get go. I connected a brand new Hyperion G3 VX 4S 5000mah pack. The truck ran great for about 45-60 seconds, then the ESC burst into flames. I've never seen an RC vehicle on fire before, but it was scary and the smell was HORRIBLE. Anyway, I was able to blow the flames out within about 20 seconds. I've included pictures below (cuz everyone loves carnage), but please also take a look at my questions.
1) What the heck could cause this?
2) Obviously the ESC is toast, but should I be worried about the motor? In the Slash 4x4 the ESC and motor are pretty close together and the endbell of the motor is blackened from the fire.
3) Is there any way to be sure my lipo is OK? It doesn't have any visible damage and it still reads full voltage.
brushlessboy16
brushlessboy16's Avatar
01.06.2010, 09:23 PM
are your deans soldered correctly?
spin the motor by hand- if its obviously hard to turn (aside from the motors natural resistance- it should be fine. and if your lipo is not puffed and is still in balance your fine
kazuaki
01.06.2010, 09:28 PM
Correctly? The polarity is correct. The solder joints seemed to be good. I installed them the same way as all my previous vehicles. Is there something specific I should be looking for?
brushlessboy16
01.06.2010, 09:48 PM
I was thinking Polarity- might have been a fluke with the ESC. call castle creations- they will more then likely send you out a new unit.
LiqrSicc
LiqrSicc's Avatar
01.06.2010, 09:49 PM
Damnit, that sucks. Your motor and lipo should be ok. You might have just gotten a bad ESC. I bought my 2 combos from the same place and they seem to be working ok so far. I'd give Castle a call in the morning.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.06.2010, 09:51 PM
Sorry to hear of your misfortune and hope you get the answers you need.
What shocks you running, I seen Green Losi springs in pic #2 ????
brushlessboy16
01.06.2010, 09:52 PM
8ight's
kazuaki
I've installed shocks from a Losi 8ight 2.0 buggy.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.07.2010, 01:28 PM
I had suspected, but are you using the 8's fronts on all 4 corners or the longer ones in the rear ? How did they work for you prior to your melt down ?
kazuaki
01.07.2010, 01:32 PM
I am using buggy fronts in the front and buggy rears in the rear. The buggy rears are on the long side. This allows a bunch more down-travel than stock. I moved the bottom of the shocks to the farthest outside hole on the control arm, this limited the down travel to ensure there is no driveshaft binding. In the front, I am not completely happy with the setup. The front shocks are also a bit long and the shocks bottom out before the chassis does. This is just asking for trouble, IMO. I will probably make an aluminum piece to bolt to the front shock tower and raise the upper shock mount slightly, so the shocks will work better. These big shocks sure have some nice damping though.
fastbaja5b
fastbaja5b's Avatar
01.06.2010, 10:08 PM
Bad luck, the MMM is a nice ESC when it's working, but it seems that when they die, they die in a rather well, explosive fashion, and when it's right next to Lipos and a not so cheap motor, that can be dangerous.
Unfortunately with any warranty claim comes disappointment and resulting downtime of an rc you're probably pretty eager to run.
Lets hope Castle can help you out on this one, they read these forums a bit, strangely they never seem to reply in one of these threads regarding a failure of their esc though.
Say Less, Do More.
01.06.2010, 10:21 PM
conspiracy theory here. castle will take care of you. they know they have failures and stand behind their product, and I stand behind them.
well, if I could stand
fastbaja5b
fastbaja5b's Avatar
01.06.2010, 10:36 PM
Certainly no conspiracy theory, just an observation.
But I can see that commenting in a thread can open a can of worms from liability to making a judgement on warranty without seeing the unit etc etc
Say Less, Do More.
George16
Supermaxx
George16's Avatar
01.06.2010, 10:42 PM
My thought exactly. I'd rather have them deal with the person individually. Castle will stand by their products. I had my own experiences returning burnt ESC's and I'm very satisfied with the customer service Castle has.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.06.2010, 11:26 PM
to the point- I would guess a binding in the driveline somewhere, or too tight a gear mesh.
It's really hard to say what the failure could have been. Maybe a fluke?
