Changing from buggy to truggy gears
brushlessboy16
brushlessboy16's Avatar
Changing from buggy to truggy gears - 01.09.2010, 05:11 PM
Just came to the realization that my savage is running buggy style gears, its limiting my gearing choicces and wanted to go to the truggy pinion to get the higher ratio diffs. Will the savage bulkheads allow for this- or do i need a different setup?
01.09.2010, 08:17 PM
Cant change to a truggy pinion as they have helical cut gears, you'd need to change both the ring and pinion gears- not sure if there are truggy ones that would be a direct fit for the savage diff cups.
Another option for a lower overall gear ratio would be to lock the truck into 1st gear instead of second, that'll allow you to have a lower overall topspeed using the same spurs and pinions you have now- same effect as using truggy gears instead of buggy ones. Not sure if thats a viable option for you, but it shouldnt be too techinally difficult if you have the parts of a fully functional tranny to play with.
brushlessboy16
01.09.2010, 08:43 PM
IM ditching the transmission in favor of a center diff..
I have seen non helical truggy diffs. I just dont know if the bulkheads will accommodate it
01.09.2010, 09:05 PM
you said change to the truggy pinion. I assume you mean ring AND pinion? It will work, but you need to keep the rings and pinions together. You can run either truggy diffs or buggy diffs, but can't mix and match truggy and buggy diff parts.
brushlessboy16
01.09.2010, 11:18 PM
brushlessboy16
01.09.2010, 09:24 PM
Then yes, truggy ring and pinions. i thought since they were the same tooth count they would be interchangable
01.09.2010, 10:04 PM
woops, I spoke without all the facts. If the ring gear is the same tooth count it may mesh. I always err on the side of caution and keep ring/pinion sets together. I also assumed a different ring gear tooth count.
Regardless, you can run truggy gears.
brushlessboy16
01.09.2010, 10:23 PM
alright, because the smaller pinion would mean that the diff would have to shift over - dont know if it would work in the savage bulkheads
01.09.2010, 11:30 PM
shim accordingly
scarletboa
scarletboa's Avatar
01.09.2010, 11:14 PM
it wouldn't work. what is the problem? geared too high? or too low? if it is geared too low, you can get an upgrade from hpi that turns the flux tranny from being locked in 1st gear to being locked in 2nd gear.
http://www.hpiracing.com/products/en/102244/
brushlessboy16
01.09.2010, 11:31 PM
My concern is that it doesnt have that much shimability (did I just make a new word)
JThiessen
JThiessen's Avatar
01.10.2010, 02:20 PM
Those new HD diff gears for the flux will solve your problem, and no fitment issues...they are a lower ratio, and have more of a truggy style cut to them. Freeze has some decent pics of his freebies in his thread in the Savage forum.
