Need a motor for E-Maxx that will run on 4s lipo. The E-Maxx is stock except for these upgrades: alum diffs and cups, steel cvds, steel center drive shafts and steel idler (single speed). This will be used for mostly bashing.
I've been running a 10L in my revo on 12 cells and its the perfect bashing setup. I get nice run times and fairly good speed and it runs cool. Should be perfect for 4s lipo.
i would personally go for the 7xl. it will run cooler and just be better over all. i would also go for the second packs. there cheaper, are capable of more amps, although there are slightly bigger, they will perform better.
10L will get you a better runtime, 10L will be easier on your drivetrain and is more than enough for bashing. The 10L will be less hard on your lipo's too.
I just checked and it shows that Mike is out of stock on the L motors. I wanted to place an order this week is there a Lehner motor that is comparable to the 10L? What gearing should I start with?
