Originally Posted by BrianG
Actually, I think Neil is right. I set the arm time to ~2 seconds on all my setups, which use Spektrum.
yes, since we have 2 different smart devices that have their own failsafes etc etc.
on an AM radio where a loss of signal equates no a nill servo pulse signal will put the MMM into failsafe, whereas a spektrum or other smart brand of radio will give the MMM the signal that it is told, hence if you didnt re-program your failsafes in the spektrum after using the same reciver on a nitro, all of a sudden the MMM will go reverse when the controller is switched off.
back to the problem at hand, the MMM isnt seeing a signal from the receiver quickly enough so it goes into failsafe, meanwhile, the receiver has just found it's transmitter and comes on-line.
