What fire extinguisher
Bazzokajoe
What fire extinguisher - 03.07.2010, 06:18 AM
As my title states, what fire extinguisher would be best for me to have when i'm out bashing?
may seem like a stupig question, but if something does go spectacularly wrong i would like to be able to bring it back under control quickly... so fire extinguisher it is :P
would a foam or CO2 one be better than a water one? as if i loose one of my components i would still like to be able to use the rest...
does anyone carry a fire extinguisher with them on bash days/have one in the car just in case?
J57ltr
03.07.2010, 09:26 PM
I use an ABC at home chemical one for the kitchen, but at work I use the C02 because it doesn't leave a mess.
Jeff
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.07.2010, 09:32 PM
You definitely DO NOT want to use water. If it happens to be a LiPo fire, water will only make it worse!
ABC foam/powder would work, but they leave a mess. I would vote CO2. The fire goes out instantly. You just have to watch and make sure it doesn't reignite while it's still hot.
Finnster
KillaHurtz
Finnster's Avatar
03.07.2010, 09:34 PM
Abc extinguishers are good for all purpose. There are special electrical ext. (E) also. Id just get an abc for the car for amy emergency.
Understand that a 2lb ext is going to give you about 8s of spray. Its enough for little jobs, but much shorter than you'd think.
maneba
03.08.2010, 01:40 PM
Great planes recommend an ABC type fire extinguisher
http://manuals.hobbico.com/gpm/gpmp0...anual-v1_2.pdf
Overdriven
Destroyer of Tires
Overdriven's Avatar
03.08.2010, 11:46 PM
As I work servicing, recharging Fire Extinguishers + Fire Suppression systems for work I thought I'd chime in here. The ABC ext. are a powder which is messy and can also corrode certain metals and finishes if left on for an extended period of time. Key word, extended. But they can be used on anything (A=paper, wood, ordinary combustibles B=gas, oil, flammable liquids C= electrical) CO2 is great with no mess and works great too, but it does not have an A rating. C02 Fire Ext are also bigger, heavier, and don't work well when there is any wind since they basically make a cloud of gas to suffocate the fire. Also some foam fire ext do not have an C rating, so lookout for that as well.
As far as store bought Fire Extinguishers go, stay away from anything without a gauge. Fire Extinguisher gauges aren't the most accurate in the world, but the little button you push and hope pops back up is even worse. First Alert fire ext are pretty much total junk as far as reliability is concerned, Kidde isn't too far behind. These are the brands you'll find at home depot + lowes. If you must purchase there, at least buy the Kidde with the metal handles + valve body, they call these the "commercial Grade". They have one thats a good size to keep in the car. The plastic heads versions (Home grade) are prone to leaking, especially in an environment like a car trunk. Also, any Fire Ext. thats about the size of a 20oz soda is really only good for a rc car, as it'll last all of 5-8 seconds, assuming the plastic head didn't leak. If you want a real commercial grade Fire Ext, find a local service company and buy a Badger, Amerex, or buckey (in that order) and it will last you a lifetime.
JThiessen
JThiessen's Avatar
03.09.2010, 10:53 AM
As I work servicing, recharging Fire Extinguishers + Fire Suppression systems for work I thought I'd chime in here. The ABC ext. are a powder which is messy and can also corrode certain metals and finishes if left on for an extended period of time. Key word, extended. .
Doesn't need to be an extended time. We had an electrical fire in a light next to one of our planes a couple months ago. The maroon that grabbed the fire extinguisher (ABC type) also shot it into the A/P. We ended up having to replace an entire skin panel due to the corrosion (cost the company about 500K in parts and labor).
I've seen stuff on this new type K general purpose extinguisher. Dont know much about it yet.....
Overdriven
Destroyer of Tires
Overdriven's Avatar
03.09.2010, 12:10 PM
I'd have to assume the panel is aluminum, which is particularly susseptible to corrosion. Also ABC works by actually melting a little bit to smother the fire, making corrosion even worsein most cases. But generally, if the surrounding parts didn't get too hot and aren't prone to normal corrosion, it isn't too much of an issue if cleanup if performed in a timely manner. At least that's my experience.
The class K fire ext are a liquid chemical fire ext with a chemical similar to that used in kitchen fire suppression systems. It is a potassium base I believe, and is a base (on the acidity scale) so I don't recommend for aluminum. It was developed for cooking equipment (particularly deep vat fryers) to supplement the suppression systems and to be used for flareups after the system is discharged. It works by soponification. It forms a somewhat soapy layer over surfaces suffocating the fire. I've been told by customers who've used them that they work very well in a kitchen environment. I'm not sure if they have an A rating, but I don't see why they couldn't be used on A fires.
Finnster
KillaHurtz
Finnster's Avatar
03.09.2010, 01:15 PM
How small do they even make CO2 ext? I would think a 10 or 20lb ext would be the min size.
Another concern is you need to get quite close w/ a CO2. An abc is more of a stream w/ better distance. Face it, if you have a battery fire in your car, you'll want to put it out regardless to some cosmetic damage to some Alu parts. They can likely be cleaned up and polished well enough w/ timely care. Much of the car is going to be pretty fried regardless.
Overdriven
Destroyer of Tires
Overdriven's Avatar
03.09.2010, 01:54 PM
The smallest co2 being made now is 5lb, they stopped making 2.5lb as they are useless. IMO 10lb is the minimum co2 size, as they can make a decent stream so you don't have to be too close, 5-10ft away would still be the max distance depending on wind, type of fire, where it is, etc. CO2 is great for real car engine fire or any fire that can't be attacked directly and is a corner not easily reached. But they are also expensive, about $225 for a 10lb, which isn't the most portable thing in the world. Get a decent 5lb ABC (don't cheap out with a 2.5) stick it in the trunk, under the sink, in the garage, etc and be done with it.
I find it funny when computer geeks want a Halatron fire extinguisher (halon replacement) for their computer rooms. They are more expensive than CO2 and you still have to be there to use it, if you're not, it's just a nice decoration. I always tell them, get an automatic fire ext ($2k and up) or don't waste your money on anything more than ABC. The computer is going to be toast anyway if it caught fire and you didn't get to it real quick. Just take a look at that mugen mrx4 fire. They got to it in time, but didn't have an ext, all it took was another min to destroy the rest of the car.
08.07.2010, 11:48 PM
...I find it funny when computer geeks want a Halatron fire extinguisher (halon replacement) for their computer rooms. They are more expensive than CO2 and you still have to be there to use it, if you're not, it's just a nice decoration. I always tell them, get an automatic fire ext ($2k and up) or don't waste your money on anything more than ABC. The computer is going to be toast anyway if it caught fire and you didn't get to it real quick. Just take a look at that mugen mrx4 fire. They got to it in time, but didn't have an ext, all it took was another min to destroy the rest of the car.
At the company where I used to work (Operations Manager), we used an FM200 system, but it was a 24/7/365 computer operations setup, so someone was there all the time. Where I work now, they use something else, can't remember the name. All I remember is the guy said that if it went off while you were in the room, you could still function (albeit not well) if you breathed a little in. Anyway, this operations is not 24/7/365, so you are right, it is useless unless automated. But now I think about it, I'm not sure it isn't; many operations centers have a pretty sophisticated fire alarm system, so it would make sense to have the extinguishing system hooked to it.
To answer the original question of what extinguisher to use: I say none. Just bring along someone you don't like and throw them on the fire.
fastbaja5b
fastbaja5b's Avatar
08.08.2010, 12:06 AM
I just have a Fire Blanket here, never had to use it yet, even with me cooking!
Say Less, Do More.
03.09.2010, 07:40 PM
I'd like to see a mini extinguisher made from a few bbgun/ airpistol type Co2 cartridges; pointless and 90% useless, but a quick blast is sometimes enough to put out a small esc fire maybe
Bazzokajoe
08.07.2010, 05:04 PM
remember this thread quys?
well i went with an abc... sodium bicarb one :)
have a look... as i used it today :P
http://www.youtube.com/watch?v=ut8xd0-H-K8
did a good job... saved the car and speed controllor... even if it did coat the car in blue!
excuse my shocking jump :P my excuse is that i couldnt see the landing...
08.07.2010, 09:22 PM
great save on the rest of the buggy! Glad you had it handy
