Buggy weights?
Bazzokajoe
Buggy weights? - 03.07.2010, 05:54 PM
I'm thinking of starting to race my hyper 7 conversion, but have no idea what a more race oriented buggy would weigh? if you could post up a pic of your buggy along with its weight it would be helpful :) i will get one of mine tomorrow evening.
thanks guys
joeling
joeling's Avatar
03.16.2010, 02:20 AM
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
Bazzokajoe
03.16.2010, 02:31 AM
is that race weight? with all electronics?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.16.2010, 03:14 AM
I spy a MMM, a Medusa motor, and a Polyquest XP lipo. So yes.
Bazzokajoe
03.18.2010, 01:49 PM
ok... so i weighed mine and it weighs 4090... quite significantly more...
anyone know how that compares to nitro models currently on the market?
bdebde
That's All Folks!
bdebde's Avatar
03.18.2010, 03:09 PM
3450 here
03.18.2010, 03:29 PM
The hyper 7 is a bit heavy, but very strong. The hyper8 is considerably lighter, but not sure if it is lighter than an xray xb8?...
jzemaxx
03.18.2010, 04:31 PM
http://www.rc-monster.com/forum/show...light=lightest
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
jzemaxx
03.18.2010, 04:32 PM
3390 mbx6. The Xray is probably the lightest....mugen 2nd
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
03.29.2010, 01:07 AM
ROAR minimum. Happens to be 3200g. Losi 8ight. Not the lightest buggy in general, but I have several tricks up my sleeve. ;)
Area 52 Ranch Raceway
T.R.C.R.
Stoomstrijkijze
04.08.2010, 06:07 PM
Could you tell me? You may pm me or post it here.
I think mine is on the heavy side. 3600-3650 with 4S 5000mah lipo.
SpEEdyBL
SpEEdyBL's Avatar
04.12.2010, 03:15 AM
1. Kyosho plastic spur removes 20g over steel
2. I use the Tekin 1900. It gives me 30-50% more runtime over my Neu Castle 2650 which allows me to use a Zippy 4s 5,000 mAh 25c pack that weighs 497g for 15 minute mains on a large outdoor track and and a zippy 4s 3,000 mAh 40c pack that weighs 352g for <12 min mains on an indoor track.
3. The mamba max pro works very well with the tekin 1900 and saves about 50g.
4. I've also tried the L8ight model shocktowers w/ the 6 outer holes removed, running front shocks in the rear. Another 30g. Really not much of a difference in handling verses the stock shock towers.
5. I've removed all unnecessary extra conversion parts, and front plastic brace. 20g
6. Titianium turnbuckles, hingepins and fioroni axles. 40g
7. Panther tires the the lightest for indoor, AKA tires seem to be the lightest for outdoor, and Associated 83mm wheels are the lightest wheels. (33g ea)
8. I persionally don't run roll bars, and I run a center spool. 25 & 30g less.
Doing all of the above should get you below 3200g and it definately pays off.
T.R.C.R.
Stoomstrijkijze
04.12.2010, 04:47 AM
Damn, that's a quite expensive mod :p
I'm running a normal 1.0 with fioroni flex chasis, front and rear adjustable toe/squat/kickup blocks, plastic spur, MMM 2200KV combo and a 4S 5000mah Turnigy lipo that weights 536g.
Last time i weighted the car it was around 3600g ready to run. I make some small changes (HD center diff etc), but I guess it should be more than 3650g now.
3500g or lower would be a nice weight I think. I'll look what I can do.
Thanks for the tip!
Btw, what do mean by front and rear brace? The plasic motor brace is not on my chasis, it doesn't fit anyway :p
SpEEdyBL
SpEEdyBL's Avatar
04.14.2010, 12:14 AM
I was refering to the brace that goes from the servo brace to the chassis. I removed it mainly to get some more chassis flex as I do not have the 2.0 chassis.
T.R.C.R.
