1/8 Rustler
Urgeoner
Urgeoner's Avatar
1/8 Rustler - 05.05.2010, 05:17 PM
Here is my Rustler, completely overhauled with a Proline Revo Slipstream Body.
Hope you like!
ID:	8846   Click image for larger version
t-maxxracer32
t-maxxracer32's Avatar
05.06.2010, 02:01 AM
looks great!
I did the same to mine but for some reason I could not get it running right.
Hope you got yours tweaked how you want it!
Urgeoner
Urgeoner's Avatar
05.06.2010, 11:52 AM
Thanks dude! It runs great and it jumps very well. only thing I'm concerned with is the Mamba Max gets pretty hot after a run, hot enough to where I can't hold my finger on the sink for too long I run 2s 25c Hyperion 5kmah, and velineon motor.
Semi Pro
Semi Pro's Avatar
05.06.2010, 09:51 PM
dont worry to much about the mm, it has thermal protection, if it starts cutting out then you may need to step up to 3cell and lower gearing
t-maxxracer32
05.07.2010, 02:11 AM
it is probably those tires that is killing your setup.. that is always what got my mm hot. once i replaced the tires with smaller ones it all went away..
as semi said.. lower your gearing and see if that helps..
Urgeoner
Urgeoner's Avatar
05.07.2010, 02:10 PM
Yea? I was thinking about stampede tires and wheels, but i love the way it handles with the 1/8 truggy tires! I'll try lower gearing first..
