Originally Posted by Gallagher
You need shim the diff, since the diff will move backwards or forwards a little bit more than when you use the stock spur gear. I use washers to shim the bearing and the diff mount.
+1
that is how i shredded my center diff on my crt x2. i didn't shim it and the gears did not mesh right, so they wore out pretty fast.
