Name that noise
jamesban
Question Name that noise - 06.22.2010, 02:07 PM
Heres my brushless muggy. I just put new HD cups and diff gears in the front and rear with 10k oil. Im running a MM 2200 and its running 13/45 with a plastic spur on 4c A123. It makes a clicking sound when I throttle it for a few seconds. It's meshed properly but since the center diff was locked when I got it and Im guessing with this gearing, the locked diff and the plastic spur that the clicking is coming from the spur and pinion but Im only guessing? Im hoping its not coming from the new diffs? Can anyone here tell by the sound in the video? Anyway I plan to get the 45T delrin slipperential next payday so if its the spur it should solve that by having some slip I hope? Thanks. You can hear it around 7 seconds, 12 seconds and 40 seconds in the video
[YOUTUBE]http://www.youtube.com/watch?v=Kmxq1v1GrFw[/YOUTUBE]
lutach
lutach's Avatar
06.22.2010, 02:35 PM
I would double check everything again. See if there's any bent drive shaft or axles. See if any pins are worn out. Check your internal gears as I had a similar situation happen to me with non hardened HB diff gears. It could be something that catches some moving part(s) at times.
jamesban
06.22.2010, 03:10 PM
All of the diff gears were brand new although I dont think they were hardened just stock replacements, I built two new diffs with HD cups and they seemed very smooth after assembly, the center diff was locked with what looks like hot glue and I left it like that. The drive shafts and axles all appear straight. Im honestly not sure what it is. I had a similar noise in my brushlass e-savage when the stock plastic trans blew apaprt from the 9XL motor runnig on 6 cells. Other than that I never heard a noise like this. It doesnt sound like metal diff gears grinding to me? I may have to wait till soemthing fails to figure it out or if the slipperential makes it go away?
bdebde
That's All Folks!
bdebde's Avatar
06.22.2010, 03:07 PM
Did you put new bearings in the diffs when replacing the gears?
jamesban
06.22.2010, 03:14 PM
Yep, rubber sealed abec 5
jamesban
06.22.2010, 03:12 PM
I also used new mugen pins but I heard no diff pins are bulletproof in the muggy from this forum?
bdebde
That's All Folks!
bdebde's Avatar
06.22.2010, 03:19 PM
If you did not replace the bearing with the diff gears, then that could be the problem. The only diff parts that wear out in my Muggy are the bearings on the rear diff pinion. Then the gears can slide past each other under hard acceleration as the pinion deflects because of the wear in the bearings. Check it out.
jamesban
06.22.2010, 03:39 PM
I used new bearings and shimmed them. I hate to take it all apart again but I guess I might have to?
bdebde
That's All Folks!
bdebde's Avatar
06.23.2010, 01:04 AM
Plastic or aluminum diff cases? If plastic, are they new?
jamesban
06.23.2010, 08:26 AM
brand new aluminum
