Castle Creations 1520 vs 1717?
Dj_Sparky
Castle Creations 1520 vs 1717? - 07.22.2010, 04:53 PM
I e-mailed Castle Creations, asking whhich of these I should put in my GST 7.7 brushless conversion, and Greg recommended the 1520. I plan to run on 6s with the Mamba Monster ESC.
But, isn't the 1717 larger and more powerful?
07.22.2010, 08:47 PM
I think its larger by volume- not massively more powerful, but it would be the better choice for a heavyweight monster like the GST. Thats assuming it will fit- that larger diameter may limit your gearing options depending on the design of motor mount you plan to use/ make.
nuz69
nuz69's Avatar
07.23.2010, 04:08 AM
The 1717 is 70g heavier so it can handle more power than the 1520, meaning that the 1717 would run cooler and more efficient for your application. But like suicideneil said it's larger and gearing can be difficult.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Dj_Sparky
07.23.2010, 06:21 AM
Hmm.. What about the 1524 or the 1527? Will a Mamba Monster ESC be able to handle either of those at 6s?
And as for motor mount.. I've asked Mike, but haven't gotten a reply yet. Do you know where else I can get someone to make me a motor mount/a mount that will fit the Neu motor?
nuz69
nuz69's Avatar
07.23.2010, 06:37 AM
In 1/8 scale vehicle yes, unless your geared your vehicles for 90 mph, those longer motor wont draw more current than the smaller one, but will run cooler and more efficient for the same top speed. Check the dimension available in your motor mount, but the neu 1524/1Y in 6S with the Mamba Monster ESC would be a great choice.
Dj_Sparky
07.23.2010, 06:55 AM
Yeah, the 1524 looks pretty good. I will start with a loow pinion anyhow, and go from there.
1524 has the same diameter as the 1515 as well, so I can just plug it into my Flux too.
But, I can't find the 1524/1y anywhere. Castle Creations seems to take several weeks to ship out?
nuz69
nuz69's Avatar
07.23.2010, 06:57 AM
try maybe off shore electrics.
Dj_Sparky
07.23.2010, 07:01 AM
They only have the 2550kv one. :(
By the way, how do I figure the 1527 isn't too powerful for the Mamba Monster esc on 6s?
The Max amp burst draw of the 1527 is 130. Not sure what the burst on the Mamba Monster is, but its at 120 continous..
But with either the 1524 or the 1527, I can just buy the regular Flux mount and drill new holes in the GST. Much simpler than the 1717 installation.
nuz69
nuz69's Avatar
07.23.2010, 08:17 AM
The power you consume doesnt depend of your motor, but of your application. Put a 1527 in a 1/10 scale vehicle, it will consume less than 30 amps continous (geared for standard speed).
If you use the 1527 at its maximum power, of course it will be a little too much for the MMv3, but using the 1527 at its max mean geared your truck for 90-100mph for example.
Geared for the same speed, a 1520/1Y or a 1527/1Y will consume exactly the same amount of current, the 1527/1Y will consume even less because little more efficient.
The 120 amps of the mamba motor is the max current the motor can consume, but in fact it never consume that current continuous. See the point too, that a 1515/1Y or a 1512/1Y or a 1520/1Y is given for the same max current, that's because the 3 motors have the same widing configuration (wires thickness and Y widings) so you can imagine that a 1527/1Y would have been the same ;)
pinkpanda3310
pinkpanda3310's Avatar
07.23.2010, 08:48 AM
I put in an order for a 1524 1y a couple of weeks ago. I was guessing it had roughly the same power rating as the 1717 but without the gearing issues. I think you will be very lucky to find one ready to ship, and if you do you might as well have waited for a new one.
Dj_Sparky
07.23.2010, 08:38 AM
Ah, ok, thanks a lot. This is why I'm worried about it, though; http://rc-monster.org/forum/showthread.php?t=19315
He burned up the MMM ESC with the 1527
But, I'm going to gear it for 35-40mph or so at first. And perhaps go faster if it handles that easily.
So, I guess I'll buy the 1527 with the Mamba Monster -- I can't get ahold of the 1524 anywhere.
nuz69
nuz69's Avatar
07.23.2010, 08:46 AM
LOL
This guys use a 1517/1D 2300Kv, in 6S on a small track !!! For your information the 1515/1D is rated for 4100Kv...
1D widings requieres a looooot of current at startup compare to 1Y, more over using it in 6S generate even more current spikes..
The 1527/1Y is around 1000Kv, 1524/1Y 1360Kv so if you dont gear your truck for 80mph it would be OK. Don't hesitate to ask the castle support if the MM can support the 1527. You will probably same kind of response, small Kv and 6S with correct gearing.
Dj_Sparky
07.23.2010, 09:44 AM
Ah, ok. I didn't think 2300kv was that high, but when compared to the 1515 it is quite high.
Anyhow, I would order the 1250kv one (1527/1Y) of course. I've already asked support, and they told me that they would work fine with Mamba. That is, the 1520, 1521, 1524, 1527.
I was looking at the wires, and this is all new to me. I guess I need some wires for the motor to the ESC, right? And I'm guessing these are it; http://www.offshoreelectrics.com/pro...=dh-ultra-wire or http://www.offshoreelectrics.com/pro...p?prod=ose-6bw
Settled on these connectors: http://www.offshoreelectrics.com/pro...=ose-6mmbullet
pinkpanda3310
07.23.2010, 10:20 AM
When you buy a mamba monster it comes with extra wires for the motor with CC bullets at one end. The monster uses 10 gauge wire. If you like to keep things simple just stock up on CC bullets so you don't have different size connectors for batt's.
Dj_Sparky
07.23.2010, 10:24 AM
For the batteries? I was going to use deans for those.. Or am I not getting what you are saying? :P
