My Custom Carbon Fiber Revo 3.3 Brushless Conversion!
Muggydude
My Custom Carbon Fiber Revo 3.3 Brushless Conversion! - 07.24.2010, 11:16 PM
Well, after a 6 months of modding, building, and buying, my conversion is finally done! She has:
Vantage Extended Carbon Fiber Chassis
MMM Black 2200kv combo
Hitec 7955TG servo
Tekno Swaybars
RC Monster Custom Motor Mount (The lower plate is an older version)(not shown in pics)
Tekno Battery Tray
DX3.0 Radio
Turnigy 5000mah 4s 40c lipos
RPM Rear True-Tracks
Traxxas Red Aluminum Turnbuckles/Pushrods all the way around
Revo Platinum lightened Bumpers (Drilled out)
Aluminum F,R,C Skidplates, with a small custom V-Armor Plate Mod
Custom Mudgaurds
Custom Aluminum ESC Mount
Tires: Badlands and Masher tires Mounted on RPM Revolver Stablemaxx - wheels, AKA Cityblocks, and Revo Platinum Response Pro Tires
Bodies: Custom Carbon Fiber Revo 3.3 body, Losi Muggy Body, and Proline
Crowd Pleazer 2.0 body
I showed pics of how I taped the tires with Gorrilla tape for both the Badlands and Mashers. I made the custom aluminum ESC mount with the Traxxas MMM mount, two sheets of aluminum sheeting, and a metal saw.
Hope you like it! I sure do....
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
Muggydude
07.24.2010, 11:22 PM
A bit on the Motor mount. First I had an older version Tekno Blue Motor mount with a CC 2650kv motor and a long shank pinion. Due to flex issues, I sold the motor and got a Castle 2200kv, along with the CF Chassis and RC Monster new gen motor mount. The newer design is made for the Revo 3.3 aluminum chassis, which doesn't have the flex in the motor area that the CF chassis does (The rest of the CF chassis, is actually stiffer than aluminum). I described my problem to Mike, and He sold me an older version of the lower plate of the motor mount, which allows me to mount it on the Nitro motor mount. This raises the Motor about 3/8', but there isn't a notable difference in handling or CG. There are now zero flex problems compared to the newer version motor mount. So for a Carbon fiber conversion, make sure you ask mike for an older version mount.
1/16 BL E-revo
Muggydude
07.24.2010, 11:36 PM
Just camE back from the skatepark.... Success! No broken parts, stripped gears, or heating problems. I must have run it for over 30 minutes total run time, cause I spent a good chunk messing around in rocks and a playground at about half speed. Not very many highspeed passes, just low-mid speed runs. The skatepark was a lot of fun, a little too crowded, but i got some good jumps in. This thing is easy to control in the air, and flies well. I think I'm going to switch to some stiffer springs, I had my setup at 60 wt oil, p2 rockers, inner hole, Black rear springs, gold front. Any suggestions for stiffer spring setup? When I got home and threw the batt on the charger, it was at 14.7 volts, so I think that's is just fine. I never even hit the LVC, or use my second batt. I really like these turnigy batteries. I'll keep you udated as I test it more. This peoject has finally come together, and I'm really happy with it! Can't stop smiling!
By the way, I have displaced all doubts about how strong this CF chassis is. It's really durable!
(Real quick Q, 14.7 volts is normal for 4s, right? I believe I have the LVC set at 3.1 volts per cell. It was just barely warm when I stopped)
1/16 BL E-revo
scarletboa
scarletboa's Avatar
07.25.2010, 02:44 AM
yes, 14.7 is perfectly normal for a 4s lipo. you were almost at the point where the cells just dump and hit lvc. you had maybe 2 or 3 more minutes of runtime left on that pack.
most higher c rated lipos run best with the cutoff set to 3.4v/cell. the newer lipos (like yours) typically dump pretty quick and you will lose maybe 20 seconds of runtime, but it will make your battery last a lot longer.
Muggydude
07.26.2010, 02:08 PM
I have a quick question for everyone. I'm planning on pick up front RPM A-Arms and axla carriers. Now, should I get all black or white front parts? The black would stick to the trucks wholetheme and the rear truetracks, but the white is cool. What do you think?
1/16 BL E-revo
07.26.2010, 02:23 PM
Black
07.26.2010, 05:57 PM
black
Muggydude
07.26.2010, 07:51 PM
Actually, I think I'll only get the a-arms. What are better axle carriers?
1/16 BL E-revo
bryan
bryan's Avatar
07.26.2010, 08:38 PM
WHITE
brian015
brian015's Avatar
07.26.2010, 09:12 PM
Originally Posted by bryan View Post
WHITE
+1
If you get white, you can dye it whatever you want - so your options are limitless. Think, there's hot pink, lime green, mustard, purple, turquoise...............
Muggydude
07.27.2010, 05:19 PM
Here are pics of the older RC-Monster Motor mount that I'm using, along with my new and improved gorrilla tape mudgaurds. I'm having a problem though. My slipper is being eaten up, and I have no idea why. This is the second time it's happened. (I've including pics of the problem)
1/16 BL E-revo
Muggydude
07.27.2010, 08:46 PM
Few things. I just weighed it today with the badlands tires, 10.2 lbs. I'm very happy with that, especially since it has all aluminum skidplates. I think with plastic skids and race tires, I could get it down to 9.5 lbs. It could be a very competitive racer! I alos ordered the heavy duty aluminum slipper pads to see if they help the problem. i'll keep everyone posted.
1/16 BL E-revo
Muggydude
07.28.2010, 04:28 PM
Woohooo! I love this setup! I took it to a very big skate park with a huge snake run and a real nice street course. Today, I must have gotten AT LEAST 45 minutes run time on each pack (Don't know how this is possible, other than again I mostly had it at about 1/3 throttle the whole time, occasionally a little more or less). I keep on think something is wrong, but I looked at the voltages of each pack and they were 14.107 Volts and 14.407 volts. I have my LVC set at 3.2 per cell, I think I'm going to go to 3.4 volts. But really, I mean this setup is amazing! The hottest the motor got was 120 degrees at the end of 2 packs, the ESC at 115 degrees, and the lipos at 109 degrees. No breakage the whole 90 minutes, except I once landed from 6 feet in the air on one tire, and both the pivot balls on each side popped out of the axle carrier, Easy fix, and I think it probably save either a broken wheel, a-arm, or part of the steering (Glad I have a titanium gear servo). Took 5 minutes to repair. I am really impressed with this truck, both in it's durability, and handling. Last night I unscrewed the rear shock shaft ends on the shokcs, and this, along with the silver and blue springs, really helped the truck not bottom out as much as it did before. I can't stop smiling
1/16 BL E-revo
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.28.2010, 04:42 PM
Was it the rear RPM carriers that the balls popped out of ? If so theres an easy fix for this.
Muggydude
07.28.2010, 04:53 PM
No, front right stocm traxxas ones. Happened the other day too, but I think on the other side. What's the fix though?
1/16 BL E-revo
